need help milling large dia
Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Nov 2013
    north of Bean town
    505
    84
    162
    Default need help milling large dia
    hey all, im making a section of a 60" dia "L" shaped bracket. ive triple checked my mastercam drawing and tool parameters. the issue is the outside dia is coming in .231 undersize and the inside dia is .353 undersize. ill post the program, the math doesnt seem right
    N2 G0 G17 G40 G49 G80 G90
    ( 1/2 ENDMILL SHARP CORNER FINISH OUTSIDE )
    N3 T3 M6
    N4 G0 G90 G54 X-7.6686 Y.5384 S1350 M3
    N5 G43 H3 Z.2 M8
    N6 G1 Z-.78 F50.
    N7 G41 D3 X-7.5476 Y.0533 F8.
    N8 G2 X7.5476 I7.5476 J-30.2718
    N9 X7.7297 Y-.2498 I-.0605 J-.2426
    N10 G1 X7.5991 Y-.7737
    N11 G2 X7.296 Y-.9558 I-.2426 J.0604
    N12 G3 X-7.296 I-7.296 J-29.2627
    N13 G2 X-7.5991 Y-.7737 I-.0605 J.2425
    N14 G1 X-7.7297 Y-.2498
    N15 G2 X-7.5476 Y.0533 I.2426 J.0605
    N16 G1 G40 X-7.6686 Y.5384
    N17 G0 Z.2
    N18 M5
    N19 G91 G28 Z0. M9
    N20 G28 Y0.
    N21 M30
    Dec 2008
    New York
    10,394
    2703
    probably a tool dia comp issue. line left and line right that is G41 and G42. obviously if using D3 what is the value in D3 ?? usually you compensate for radius / dia of cutter or you use wear comp from theoretical max size of cutter. that is selected in mastercam usually. also is D3 in radius or dia and what is needed. that is does D3 need to be .250 or .500 for a 1/2"dia end mill. different machines expect radius and others in diameter
    or you somehow messed up selection arc or circle
    Mar 2011
    MASS
    981
    426
    309
    can you post the mastercam file?
    Dec 2008
    New York
    10,394
    2703
    i have also seen where G17 G18 G19 or plane selected when incorrectly given messed up tool comp. usually G17 is used but 5 axis machines often G18 or G19 is used
    Jun 2012
    Michigan
    5,370
    5012
    3335
    What is your comp set to in Mastercam? Control? Wear?
    Nov 2013
    north of Bean town
    505
    84
    162
    D3 is wear comp..should start at zero. they are undersized by different amounts which is perplexing, but all the other dims are in besides the bolt circle which is also .375 too small. it may be my cmm having a hard time on such a small portion of the dia. i making a section that is 28 deg of the whole circle(about 15" long)
    my program has the same noemclature they have had for 10 years, nothing differnt.
    the way i drew my drawing was creating the 60" circles then segmenting 28 deg then moves everything to origin in mastercam. ive check the dias in the mcam file thay are spot on.
    N8 G2 X7.5476 I7.5476 J-30.2718-----this here is where the tool makes the arc on the outside. the J-30.2718 should be 1/2 dia(61.897/2=30.9485+.250(1/2 tool)=31.1985..Right????? but the starting Y is not zero tho it shoudnt matter??
    Nov 2013
    north of Bean town
    505
    84
    162
    tab.jpg this is after backplot
    Sep 2015
    Ohio
    1,412
    941
    1409
    When I plot the end points of your OD arc along with the center of the arc I get R31.25
    For your ID arc I get R29.232
    Dec 2008
    New York
    10,394
    2703
    might be more a measuring problem.
    but also cnc dro calibration that is have you measured when you moved 10.0000 using a gage block against stop and indicator and zero dro and remove gage block to travel til indicator is zero at stop what does dro say ?
    that is you can move 9.995 but dro says you moved 10.0000. better machines have a calibration mode to fix dro errors. just something to check too.
    also higher feed rates a cnc does not always track or move as accurately as when you travel at slower feed rates
    just saying i have seen dro needing calibration before on each axis X and Y and Z
    Jun 2012
    Michigan
    5,370
    5012
    3335
    Quote Originally Posted by tay2daizzo8 View Post
    I can draw it here at work and post my code for cutting the shape to see if mine is different, what is your OD,ID and angle per side if the segment?
    And the dia of the cutter you're using?
  11. #11
    Sep 2016
    UNITED KINGDOM
    29
    13
    We had a similar problem, we needed to put a linear move on as you put the comp on.
    Its under the lead-in lead-out settings. Worked for us.
  12. #12
    Sep 2010
    Victoria Australia
    3,946
    1618
    Quote Originally Posted by Booze Daily View Post
    Hello Booze,
    How do you get those numbers? I get:
    OD = 31.1985 (30.9485 corrected for 0.25 Tool Rad)
    ID = 30.1585 (30.4085 corrected for 0.25 Tool Rad)
    Regards,
    Bill
  13. #13
    Nov 2013
    north of Bean town
    505
    84
    162
    Quote Originally Posted by Mtndew View Post
    .500 dia endmill 61.897 OD 60.817 ID 28 de total segment
    also shifted the center of the arcs down in Y -30.2185
  14. #14
    Nov 2013
    north of Bean town
    505
    84
    162
    Quote Originally Posted by Paul Hope View Post
    i have a perpendicular lead in of .500.
  15. #15
    Jan 2019
    Arizona
    1,117
    100
    436
    Try this
    N3 T3 M6
    N5 G43 H3 Z.2 M8
    N6 G1 Z-.78 F50.
    G41 Y0.300 D3 F8.0 (LEAD BEFORE THE START POINT OF ARC)
    N7 G01 X-7.5476 Y.0533 F8.(TOOK OUT G41 HERE AND PUT IT ABOVE)
    G1 Y0.3 (LEAD OUT AFTER ARC)
    N17 G0 Z.2
    N18 M5
    N19 G91 G28 Z0. M9
    N20 G28 Y0.
    N21 M30
  16. #16
    Jan 2019
    Arizona
    1,117
    100
    436
    when your using a d offset as 0(tool centerline) instead of the tool dia you only need a few thousandths of lead in and lead out.
    if you use your D offset as a tool dia some machines you have to put the amount of tool offset and a tad more in the lead in.
    Hass and fadal you can get away with .01 .05 or what ever if your programing tool centerline ie tool offset 0
    your problem appears to be your g41 was right to the start point of the arc. you need a lead to the start point of the arc in which you didnt have.
  17. #17
    Nov 2013
    north of Bean town
    505
    84
    162
    i changed the program and added the extra move. ill let you know how it worked when its done in 3 hours.
  18. #18
    Sep 2015
    Ohio
    1,412
    941
    1409
    Quote Originally Posted by angelw View Post
    Hello Booze,
    Regards,
    Bill
    Oops. I accidentally used J as the absolute coord of center instead of incremental distance to center.
  19. #19
    Feb 2008
    MI, USA
    907
    70
    371
    I was wondering what the material is and how big. Is it like in that screenshot you posted, made out of a solid bar? Is the material cold rolled?
    I didn't calculate radii or pay enough attention to whether it was indeed your cutter comp lead-in that may be causing it. But I do know that if you are cutting cold-rolled stock, it tends to go all wonky when cutting all around like that, especially something so long and thin.
    I'd make sure that you're leaving enough stock between roughing and finishing cycles. You will also want to make sure you strategically unclamp and reclamp the part after roughing, to allow it to spring/bow whichever way it wants to so when you finish it, it is more stable unclamped.
    I hope your issue is more cutter comp lead-in related and can be fixed by suggestions above. Otherwise you may want to look into this.
    I think that with any bowing issue on such a short segment of a large diameter like this, your CMM may throw you all kinds of wonky readings.
  20. #20
    Nov 2013
    north of Bean town
    505
    84
    162
    right now the material is aluminum to set up on, but will eventually be a duplex stainless. Im beggining to think its my CMM some how because even the holes on the bolt circle are off
    yes im making it out of solid plate
