Need help for Mori Seiki SL-4
Results 1 to 6 of 6
    Dec 2019
    Massachusetts
    Post Need help for Mori Seiki SL-4
    I have the problem with machine Mori Seiki SL-4 CNC machine
    The power ON and the hydraulic work but the drive it work but the contactor not active
    and the coil for the relay not active and No alarm in the control
    I need the support for that
    Thank you.
    Mar 2014
    CANADA
    Ontario
    803
    804
    161
    Hi does it have a fanuc 6T control? If it does you have to hit the CON button once then wait a few seconds and push it again.
  3. Likes solidworkscadman liked this post
    Jun 2011
    New Jersey
    916
    548
    351
    Correct.
    After Main on, then Power on, then "Control On" to fire up the CNC.
    The rule is three buttons on, three buttons off.
    Dec 2019
    Massachusetts
    Good morning
    The technician from Fanuc coming and test all Fanuc board 6T and I have the same problem
    I test the push the button 2 time but the same problem.
    Sep 2006
    Long Island, New York
    641
    253
    94
    Quote Originally Posted by Mou View Post
    Thank you.
    I'm not exactly sure what you're saying here but I think we had a similar problem with an SL-2 and it ended up being the main breaker.
    One leg wasn't making contact because it was old and worn out. Part of the machine would power up but we couldn't power it up all the way.
    You can check by checking all 3 legs going in to and out of the breaker and make sure they're all getting power.
    The way the breaker was made though, was good because I was able to take it apart and shim the bad contactor in there until a replacement arrived.
    Hope that helps.
    Mar 2011
    MASS
    956
    407
    300
    I have a few fanuc 6t boards if you end up needing one,
    I just scrapped a couple machines that ran good and kept the boards
    Ill give you a much better deal then buying from fanuc
