I have a 2412 ,05 model my spindle was loud I bought a sound meter from radio shack and at 8000 rpm
it was 92db the manual said it should be no more than 73db I didn't want to use the machine because it was so loud.
Someone sugested to change the belts first before repacing the spindle bearings .
So I took the old belts off and noticed the rubber was breaking down from oil geting on them
they were sticky and goooey.
Any way I replaced them with these Spd belts that are oil restant .Its a white material not sure what.
(This is the belt for the 2412)
https://sdp-si.com/eStore/PartDetail.asp?Opener=Order&PartID=74377&GroupID=1022&Qty=0
https://sdp-si.com/index.asp
After changing the belte It sounded like a new machine again .
At 8000 rpm the noise coming frome the machine 3 feet away was only 70 db.
Tim
