techbunny2000
- Jun 8, 2020
Hello everyone
I have been a reader to this useful forum for many years and it has helped me many times but now I have a problem. We have an old Mori Seiki MV35/40 CNC mill which has worked great for many years but after I repaired a hydraulic leak in the ATC cyclinder it developed a new problem. I noticed that the spindle would take a long time to spool up to the desired RPM and the CRT display would not register any "actual" rpm (actual RPM = 0). The spindle does rotate to the programmed RPM but it take a long time to reach the desired RPM and it has no torque behind it. When I try cutting at a heavy load the rpm drops down with no compensation to the load???
The machine will do successful tools changes and there are no problems with the X,Y, or Z axis. I do have manuals and have been trying to trace the problem; spindle encoder signal, signal conditioning, etc. Any suggestions or recommendations would be really appreciated.
