macds
Hot Rolled
- Jul 24, 2008
- Milverton, Ontario, Canada
Last week I went to fire one of the Fadals up, and when I went to zero it, the rotary axis faulted out.
Tried resetting, checked all fuses, etc... couldnt find anything wrong.
Assumed the cable or motor went for a dump, had work to do on it. So I disconnected the 4th and put the plug in.
Machine would then power up and home, got parts made.
Was running some very light aluminum work in it last Thursday, no problems.
Friday morning I go to power it up, and I hear what sounded like a bug zapper at the top of the machine (at power on, not even homing yet).
Smoke coming from the Z axis motor connector... SOB, quick shut it down.
Climb up, and disconnect the motor connector (power, not resolver) to inspect... the pins are burned off the motor, and the plug end of the cable is just carbon now.
So ok, I dont have time to piss around with that... work to do. But Ive got 15 tools in the machine.
Fire the machine up with the motor plug disconnected, and as soon as I threw the disconnect the freaking plug arced to itself!
Now, Ive worked around machine tools, automation, and all kinds of equipment for a lot of years.... and Ive never seen that on a servo motor, never mind the lead self arcing.
Is losing the 4th, and then the Z motor\connector leads burning up connected, and what should I try to troubleshoot before throwing parts at this bloody thing?
I do have another fadal I can swap parts for troubleshooting, but Id rather not burn them up and not be able to make parts on my good machine.
