Need Help trying to attain an 8 RA surface finish on a VMC.
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Jul 2019
    North Carolina
    7
    Default Need Help trying to attain an 8 RA surface finish on a VMC.
    Hey all, first post here, but need a bit of advice. My shop recently quoted a part that should really be on a cylindrical grinder (Tight tolerance bores, concentricity, and true positions) as a mill job, simply because they could only find the stock in plate form. So now I've got these parts to make, and I'm racking my brain as to how to do it. I've only been in Machining for 2-3 years and could really use some tips. Here's what I know-
    my parts are shaped like bushings with hats, (Probably not allowed to share details and specs, you know- Top secret stuff) .228 thick, about 1.750 in diameter. My stock is some 4340 aircraft grade steel, arriving in plate form, 12x6x.25. My only forms of workholding are a 6 inch vise and some clamps, but I have no subplate.
    I was originally planning to cut the stock into 2x6 inch strips and roughing the bottom hat, then holding them in softjaws in the second op.
    The biggest issue I'm having, however, is figuing out how to get an 8 RA surface finish on the part. I've never seen an 8 RA finish on a VMC, let alone on an Okuma Genos m560, in steel, no less. I've only got 50 parts to do, but I feel like my tooling costs are going to be at least 2k or something. I have a lot of ER32 collet holders and a few nominal set screw holders for weldon shanks, along with two .75 milling chucks.
    It's a lot to ask, but please help a new guy out. I've looked into some grinding bits for the mill, but most can only get a max of 12 RA from what I've seen.
    Feb 2005
    9,389
    15394
    11307
    So a really short flanged bushing??
    What kind of tolerances are we looking at here? And are
    there any loose tolerances (those areas give you something to
    grab in some soft jaws)
    Aug 2002
    West Unity, Ohio
    26,570
    6982
    8940
    An 8 in a mill with soft steel?
    "That's a Tuffy"
    This is the bore that needs to be so smoooooth - right?
    I would leave a bit of stock and send it to your neighborhood honing shop.
    Check with them as to amount of stock to leave.
    And hopefully they can finish that low in soft material.
    They would likely need to 2 or 3 stage them with different grits to hit your target.
    We use'ta run some small shafts that got ground to either and 8 or a 6.
    They were like a mirror (prolly the 6), but 8 wouldn't be too far from that.
    What I find more concerning is that you are wanting to run a bushing in a vice.
    Hopefully you make some full profile soft jaws to keep from oblonging the hole.
    I guess the hone guy would straighten that out for the most part, but he's not going to like dealing with it.
    If your nice surface is anywhere other than the bore, have fun!
    Think Snow Eh!
    Ox
    Sep 2002
    People's Republic
    4,830
    503
    2936
    yeah, you need a second op, really cannot machine an 8
    would have to know more about dimensions and tolerances to get better advice on any way you can automate the finishing yourself
    Jun 2019
    New York
    16
    7
    For getting a nice finish in a bore, you could check out roller burnishing. I've been able to achieve 4-6 Ra finishes in 316 SS using burnishers. Not sure about 4340. You'd want to have a nice reamed hole first.
    For the rest of the part, hand polishing?
  6. Likes Dan from Oakland, dstryr liked this post
    Jul 2019
    North Carolina
    7
    So my ID Bores on two sides are both .875 +/- .0005, and all of my outside surfaces are +/- .005 or .001.
    I've considered hand polishing or grinding as many surfaces as possible on the surface grinder, but I still have the ID work to consider.
    Material is also being heat treated and coated afterwards, and the dimensions are after coating.
    Jul 2019
    North Carolina
    7
    Yeah, the engineers and top brass refuse to let our machinists look at parts before they bid them. They usually pick weird stuff and assume we can do it, but don't like when we tell them we can't do it with what they have.
    It's a pain, and I want to usually rip my hair out over it. Will see if they're willing to export to another shop for honing, not sure if that's in the profit margin at all (They like to underquote for some god awful reason.)
  9. Likes Bobw liked this post
  10. #8
    Jun 2019
    New York
    16
    7
    If you experiment with the feeds and speeds, you can usually attain a nice finish by boring those .875 IDs. Assuming you have a nice boring head.
  11. #9
    Jul 2019
    North Carolina
    7
    Quote Originally Posted by Buttpoop View Post
    No boring head, just some accupro endmills and Mastercam.
  12. #10
    Nov 2014
    Florida
    5,214
    2075
    2559
    Quote Originally Posted by jrk190 View Post
    Not going to happen, sorry. I have no problem with Accupro, we use them everyday... on aluminum. At the very least you are going to need a better endmill, like a Garr, MA Ford or something. You could probably mill +/-.0005", but if there are any other tolerances like roundness you are going to be in trouble IMO.
  13. #11
    Aug 2002
    West Unity, Ohio
    26,570
    6982
    8940
    Well, doo the H/T before the grind/hone opps for sure!
    Harder material produces finer finishes much easier.
    Think Snow Eh!
    Ox
  14. #12
    Jun 2019
    New York
    16
    7
    Bummer.
    If thats all you have to work with, try interpolating @ 75-100 SFM @ .0005-.001 IPT with 2 spring passes. I know it looks slow, but the lower SFM will not cause as much deflection/harmonics resulting in better surface quality.
  15. #13
    Dec 2014
    CANADA
    British Columbia
    1,288
    361
    590
    “We, the unwilling, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, for so long, with so little, we are now qualified to do anything with nothing.”
    Good luck
  16. Likes mhajicek, Bobw, jz79, chip_maker, Mike1974 liked this post
  17. #14
    Feb 2008
    MI, USA
    894
    68
    363
    Cut round blanks out of plate (laser, water jet, or simply mill them. Hougen drill even?) and send them over to the lathe.
    Let me ask you: do you even have the means to measure surface finish?
    I only ask because if you are told to hold an 8 in a mill, someone (production manager or other blameable person) doesn't know what they are doing there. And as a parallel thought, probably doesn't know what an 8 is, looks like, or how to check it. It sure isn't "shiny"
    You will want to HT the part first, btw. Do not do HT afterward.
    Where is the 8RA called out at? OD, ID, and face?
  18. #15
    Sep 2002
    People's Republic
    4,830
    503
    2936
    1.75 dia 4340 from mcmaster 85 bucks for 3 feet
    that's the real sin in all this
    If I had to make them on a mill I would turn them in the spindle
  19. Likes Ox, Bobw, dstryr liked this post
  20. #16
    Feb 2008
    MI, USA
    894
    68
    363
    I agree with that. However, I wonder if this job is military work and the material needs to be DFAR compliant. I know I have had to make plate stock round in the past. I have no idea if the mcmaster material is; you could probably call to find out.
  21. #17
    Jul 2019
    North Carolina
    7
    Quote Originally Posted by dandrummerman21 View Post
    ID and OD. We really don't have the capabilities for it. Only grinder we have is a crappy secondhand surface grinder I just made a wheel guard for on the bandsaw and need to grind the chuck in on.
    They claim they couldn't find the right mil spec. material or something in anything other than plate which I find awful hard to believe. Our one chance for this part would've been on the lathe but can't do it out of plate on the lathe.
    Another case of making chicken soup from chicken scat.
  22. #18
    Sep 2002
    People's Republic
    4,830
    503
    2936
    then rough the blanks on the mill and finish on the lathe
  23. Likes 5 axis Fidia guy, J Gilles, Ox liked this post
  24. #19
    Sep 2017
    Wisconsin
    1,043
    247
    669
    I think the only way you're getting that finish on a mill is if the print is in metric LOL.
    We just had to roll burnish some 48Rc nodular iron to get an internal bore to a 12 microinch finish and it was a huge pain.
    I've cut 9-11 microinches in the Swiss but I don't think I'd try it on a VMC. Best bet for an endmill might be a helical boring operation?
  25. Likes Ox liked this post
  26. #20
    Jun 2013
    Washington
    123
    25
    Nothing is impossible to the person that doesn't have to make it work. :-)
    I've heard of shops normalizing 4xxx steels before machining.
    Laser cut does not sound like a good idea, 4340 is 'almost' air hardening.
    Round stock sounds nice but you may lose more than you want cutting wafers.
    All I can do is wish you luck.
  27. Likes jrk190 liked this post
