Need Parameters for Miyano BNC34T with Fanuc OT-A
Likes Likes:  0
Results 1 to 5 of 5
    Mar 2013
    15
    Default Need Parameters for Miyano BNC34T with Fanuc OT-A
    I have a 1990 Miyano BNC34T and all parameters, programs, and offsets got wiped out. Does anyone have Diagnosis and Parameter Values?
    Control is a Fanuc 0T - A
    Machine was running great and decided to replace key pad membrane. Bought one off Ebay and when mounted apparently wasn't a good fit and was pressing the keys. When I powered up the machine it zapped everything. Wow. Lesson learned on that one.
    Any help would be greatly appreciated.
    Thanks.
    Jul 2005
    Cottage Grove, MN 55016
    7,657
    4119
    4564
    I suggest you investigate another forum that has CNC in the title.
    May 2006
    Burlington, North Carolina
    407
    456
    156
    We had a similar problem on a BNE-34S. There should be a copy of all the parameters in with the documentation. If not, check the electrical cabinet. Only problem is, you'll have to input them all manually.
    Mar 2013
    15
    I found an old backed up copy of parameters and was able to key everything back in. Up and running again. Would have been a boat anchor otherwise.
    Jan 2019
    Arizona
    677
    59
    234
    Quote Originally Posted by DPM View Post
    no it wouldnt have, miyano/citizen still keeps the org parms for the org configured machines. they just need a serial number. only problem is you wont get the option parms if they were installed in the feild, if the options were install at factory you will get them.
