Hi All
I have an Ajax apollo lathe with a Fanuc 21i-TB control and am attempting to profile the attached part using the following program section;
(PROFILING TOOL);
T0808 G96 S1200 M3;
G0 G40 G95 X47. Z1. M8;
G4 U1.;
G71 U1. R.1;
G71 P10 Q20 U.1 W.05 F.3;
N10 G0 G42 X0. Z1.;
G1 Z0. F.15;
G3 X27.71 Z-24. R16.;
G1 X24.06 Z-27.16;
G2 X28. Z-34. R4.94;
G1 X45. Z-38.5;
X46. Z-39.;
N20 G0 G40 X47.;
G70 P10 Q20;
G0 Z50.;
M9 G40;
M5 G30 U0 W0;
M30;
The tool I have is a dnmg 93degree turning tool with 0.8 tip radius, and is setup as type 8.
The Interference in NRC error happens when the program gets to the G70 command. The G71 roughing cycle seems to work fine.
I am not a professional programmer, i usually only do simple programs. This is the first time that i have tried machining an undercut and used type 2 roughing cycle.
I have seen a couple of old posts about this error, but they didnt help.
I have tried moving the G42 command outside of the roughing cycle, just after the dwell line, and messing with additional moves when I call G42, but cant fix the problem.
Any help would be appreciated.
Tom
(PROFILING TOOL);
T0808 G96 S1200 M3;
G4 U1.;
G71 U1. R.1;
N10 G0 G42 X0. Z1.;
G1 Z0. F.15;
G1 X24.06 Z-27.16;
G1 X45. Z-38.5;
X46. Z-39.;
N20 G0 G40 X47.;
G70 P10 Q20;
G0 Z50.;
M9 G40;
M5 G30 U0 W0;
M30;
Tom
