mpascino
- Feb 28, 2012
- Coventry, CT
This may be be a silly question, but we manufacture a bunch of parts that we've made fixtures for over the years. All of the fixtures are lined up with the table or t slot edge, clamped down, and then zeroed by dropping in a 5/8" pin in a tool holder. For the parts made on these fixtures, the accuracy is sufficient and it's a quick setup. All of the smaller machines have handles that make this easy to do, if you are not aligned with the hole and manually lower the spindle, you feel it quickly and make the proper adjustments. We have a larger Mill (no directly connected hand wheels) that I need to start running these fixtures on. I've already "broached" the alignment hole on one fixture attempting to set it up the way we have done for years. Does anyone have a suggestion on a method we can utilize without having to indicate in the edges of the fixture or utilize an axial indicator everytime? Appreciate the feedback and suggestions.
Regards,
Mike
Regards,
Mike
