Never machined p20 --- NEED HELP ASAP!!!
Results 1 to 14 of 14
    Nov 2004
    Ontario Canada
    334
    7
    Default Never machined p20 --- NEED HELP ASAP!!!
    we have a rush job that needs machining tonight (friday)... and i've been nominated to do it... however it is p20 and i've never machined p20 before, or anything hardened for that matter.
    right now someone else is working on it and i am to take over, however they are just working on picking up locations, and setup... and no doubt i'll have to do most if not all of the machining.
    the machining itself is relatively simple work, however tedious.
    we have plugged 6 positions on a mould, which are 90 degress 3 axis work. they were welded in. they are on angled faces which need to have the weld machined out of them, as well as machine down the plugs to match the faces.
    the faces will probably need to be machined with ball nose cutters 3d work..
    the plugs also need a 7mm hole put in them as a "die button" which has to mate with punches in the other half of the mould. we've ordered a carbide 7mm reamer as well as a .010" - .015" carbide drill which is under 7mm (can't recall the exact size off the top of my head).
    i do not think we have through spindle coolant. SO.. with the carbide drill, i know with TSC drills you can not peck and the coolant still gets through obviously... but with just a standard carbide drill, do you still not peck?? will the drill not get severely hot if not/weld chips/etc? i'm not sure on the exact depth of the holes, as this is all being thrown at me today (friday afternoon)... the other guy ordered a spot drill... but as is my understanding you do NOT spot with carbide drills or it'll wreck the edges pretty quick, and that carbide drills hold their location without spotting. but since location is critical, perhaps if i just do a SMALL spot, just enough more to guild the middle of the drill, not enough that the edges will cut into the chamfer of the spot drill? then we are following it with the 7mm carbide reamer.
    what sort of speeds and feeds can i look at? peck with said drill or no? spot or no? how about the reamer? never ran a carbide reamer before... treat it just like a HSS reamer but the fact that it's carbide allows it to machine hardened peices?
    how about the welding, how hard is it to machine? have never machined it before... what sort of speed/feed can i start with as a starting point for my ballnose cutter?
    i know Speed and feed is all "estimate" untill in the actual situation... but i need help desperately as to where to even begin, so any suggestions would be great....
    ANY Help at all will be greatly appreciated... as i'll be working on this in a few hours... i'm not looking forward to it and don't have a good feeling about it, as i've never done work like this before... the last thing i want to do is break a carbide reamer or drill inside these holes... but also not breka the tooling cutting edges as, you guessed it, we only are getting one of each...
    Thank you! I'll be checking back in a couple of hours!
    Aug 2009
    Nevada
    1,684
    187
    466
    Not hard material to machine just a little gummy and abrasive. We used to machine p20 all day long and we made pump bodies that held .0002 over 450 degrees. Check with online speed and feed charts if you worried and try not to work harden the material. You will find its more like a harder mild steel than anything.
    Oct 2005
    England
    3,045
    24
    699
    P20 is not 'too' bad as far as machinability goes
    Ok yes it work hardens to some extent, but not as much as other tool steels that harden as soon as you even think about machining them
    I used to do punch and stripper plates out of P20 drilling 2000 0.050" odd holes in each
    What we used to do was use a proper BS style center drill eg a BS 1 center drill and drill the center so that the hole dia at the top was slightly smaller than the finished size of the hole, then run the drill in pecking 1 D deep , keeping the RPM low and the feed high (4"/min rings a bell, but dont quote me on that)
    With a 7mm hole I'd be tempted with a BS4 center drill, followed by a 6.8 drill, then the carbide reamer.
    The only real advantage we find with the crabide reamers is that they tend to hold their size better than the HSS ones in a production enviroment
    Boris
    "free cookie for spotting the spelling mistake"
    Oct 2007
    South West Canada
    2,163
    449
    Quote Originally Posted by Boris View Post
    Boris
    Crabide reamers...
  5. Likes awander liked this post
    Mar 2009
    Brunswick Oh USA
    4,555
    5143
    2717
    Quote Originally Posted by Dave Cross View Post
    Crabide reamers...
    Of course, how easy to spot. You spelled reemor wrong!
    Ray
    Where's my cookie?
  7. Likes Mtndew liked this post
  8. #6
    Jun 2008
    Tennessee
    290
    Quote Originally Posted by IAMATT View Post
    0.0002" over 450 degrees is pretty good
  9. #7
    Aug 2007
    Bakersfield, CA
    761
    74
    Quote Originally Posted by Slapstick View Post
    Hardened to what?
  10. #8
    Oct 2007
    detroit,mich.
    4,704
    4710
    418
    Thankfully none of those (P20 or any tool steel) work harden as high or easily as 304 and most other 300 series stainless steels!
    Jeff
  11. #9
    Jun 2002
    CANADA
    British Columbia
    2,672
    2212
    Default machining P-20
    Hi Slapstick:
    You may find that the areas around the welds are hard compared to the rest of the block...P-20 is often deliberately flame hardened in wear areas like shutoffs by moldmakers who want to give a cheap mold a longer lifespan.
    I do a lot of laser mold welding and it definitely is harder around the weld than elsewhere on the block.
    The large mass of the block and the small size of the weld means that the weld will be quenched by the block drawing the heat away almost as quickly as an oil quench.
    Expect to go through a few cutters as you cross the weld zone.
    If you're lucky it won't be too bad, but buy a few extra cutters just in case.
    Cheeres
    Marcus
    www.implant-mechanix.com
  12. #10
    Nov 2004
    Ontario Canada
    334
    7
    Thanks guys for the reply.
    Everything went ok. We decided that rather having me stay late friday night burned out, that i would put the holes in, while another guy came in saturday morning for the ballnose work.
    since i had no experience with this before (though i have read up on it), i followed what the other guy told me to do.
    The spot drill broke... i had a feeling it would as the relief angles were pretty steep and it didn't have much meat behind the cutting edge. i ran it at 1200 rpm and 2 IPM feed rate. We also could not use coolant since there was electrical work inside that could not get wet.
    But i knew the carbide drill is rigid enough without spotting... i ran it at 1000 rpm and 2ipm feed as well. using 2mm pecks dry, and a total depth of 1.5". The drill survived but one cutting edge was crumbled and the other was a little worn.
    Now i did what the other guy told me to do, as he was more in charge of the work, and despite me not agreeing with him... if anything went wrong... i wanted to do it the way he told me, not that i did it my own way, and someting messed up.
    if i were to have done it my own way, i would have skipped the spotting all together. i would have NOT pecked with the carbide drill. As both spotting and pecking are not reccomended for carbide drills, but he didn't seem to know this when i mentioned it. I have experience with TSC carbide drills, and not pecking, but would have been a little nervous not to peck with no TSC running through the drill.. but pecking causes chipping when chips get stuck under the cutting edge, and spotting causes chipping as there are the two different angles... but, i did what he told me to do just in case anything went wrong.
    Thanks all for the help.
    with that, my question still stands... with TSC carbide drills not pecking isn't a problem since the coolant is getting right to the front... with non TSC carbide drills... what do you do? no coolant is getting to the cutting edge, but pecking is bad... so which is better?
  13. #11
    Mar 2010
    San Marcos CA
    carbide eg should be e.g.
  14. #12
    Jan 2014
    Temecula, Ca
    3,075
    1344
    4000
    Quote Originally Posted by thndrbug4u View Post
    thanks, I've been confused for the last 11 years.
  15. Likes Mtndew liked this post
  16. #13
    Jul 2006
    Hillsboro, New Hampshire
    8,507
    2056
    5917
    Was this a "better late than never?" moment, or just a random drive-by editing?
  17. #14
    Jun 2013
    Washington
    95
    17
    Hey Boris, forget the cookie: I'll take a crab salad, thank you. :-)
