LMM
- Jan 9, 2020
- Camas, Washington
Hello all, I apologize for posting this in a bit of a general forum instead of the phase converter/transformer section. Rather than PM people, I thought some of my Brother brothers might be more likely to see this here and help out.
I just had a new S700X1 delivered today and am running into some issues I thought you might be able to help with. I know a couple of you are running similar machines off an RPC or at minimum running the 3 phase through 2 transformers after your converter. Here is one reference (RPC with 2 buck/boost): https://www.practicalmachinist.com/vb/cnc-machining/new-machine-day-brother-speedio-356518
I am attempting to run my machine in a similar fashion and am getting some strange results on the output from the transformers.
I was hoping someone might be able to lend some advice on the wiring used?
I currently have mine set up in the attached configuration. (or they should be)
Should I be connecting the generated leg from the RPC to a specific leg in that diagram?
Thank you for your help.
