Mori Seiki SL3 with Fanuc 6T DOESN'T MOVe
Results 1 to 11 of 11
    Jul 2017
    BOLIVIA, PLURINATIONAL STATE OF
    5
    Default Mori Seiki SL3 with Fanuc 6T DOESN'T MOVe
    Hello everyone,
    Recently a friend bought a used Mori Seiki SL3 with Fanuc 6T Controller.
    We started making simple programs very quickly and one day the machine just didn't move. When I turn the machine on I used to type G28 U0.0 W0.0 to move to reference point but this doesn't work anymore. The only way I can move the machine is in JOG mode or with the handwheel.
    I can't run any program or MDI sequence.
    Has anyone any experience with this kind of problem? How can I know what is wrong with the machine?
    I have a video that shows what I'm doing and the results.
    Thank you very much in advance.
    https://youtu.be/aX_UL73o0Hc
    Feb 2010
    Washington State
    421
    576
    153
    You need to home the machine when you power on the control each time.
    Power on the machine and place the mode switch in the ZRN position (see the picture below, red arrow).
    You should be able to jog the axis in that ZRN mode, but when you get close to the home position, they will slow down as they hit the deceleration dog. Keep pressing the jog button until the axis reaches the home position. You have to do this procedure for each axis every time you start up the machine.
    Check your operator manual, it probably has more specific info.
    That's the standard way for most Fanuc controls (and most machines in general).
    Jan 2014
    Washington
    4,096
    767
    2170
    Quote Originally Posted by diecal2112 View Post
    Hello everyone,
    Lots of old Mori machines have the low way oil float switch tied into Feed Hold or Single block signals so the machine won't run if the oil is low. Check that first.
  4. Likes cwtoyota, twr liked this post
    Jul 2017
    5
    Thanks for your answer!!!
    I tried to do this procedure when turning the machine ON. I referenced the axis the way you indicated and the leds for each axis turned on.
    Yet the machine doesn't move in automatic mode.
    Jul 2017
    5
    Quote Originally Posted by cwtoyota View Post
    Jul 2017
    5
    I checked all the oil levels and they are normal.
    What else do you think can be the problem?
    Dec 2014
    Michigan
    686
    334
    430
    There is a condition stopping you from executing "cycle start". If you can view the ladder logic do a word search for G7.2 (cycle start) to find which condition is not being made. If the control wants a password to look at the ladder logic use "L" and hit the input key.
  9. #8
    Jan 2014
    Washington
    4,096
    767
    2170
    Quote Originally Posted by Other Brother View Post
    .....If you can view the ladder logic do a word search for G7.2 (cycle start) to find which condition is not being made. If the control wants a password to look at the ladder logic use "L" and hit the input key.
    6 series controls did not have the ladder viewable on the screen. Also the Diagnostics were not sorted by address. You'll need a hardcopy of the ladder diagram and a Fanuc 6 maintenance manual to trace the Cycle Start signal and find which Diagnostic number Cycle Start is.
  10. #9
    Jul 2009
    Peoria, IL
    11,631
    50
    8878
    If you have a copy of the ladder, you might be able to figure it out.
    Is the chuck clamped?
    Is the lube system pressure switch working?
    Is the tailstock retracted?
    Is the edit lock switch turned to "lock"?
  11. #10
    Jul 2017
    5
    Quote Originally Posted by ewlsey View Post
    About these questions,
    The chuck IS clamped.
    The tailstock IS retracted.
    The edit lock switch IS turned to "lock".
    I don't really know how to check the lube system pressure switch. How can I do that?
    Also I don't have the manuals for this machine, I serchedd everywhere I could and didn't find it
  12. #11
    Jul 2019
    MEXICO
    Default Fanuc 6t
    Hi friend
    I have a similar problem with a MAZAK M4.
    I would like to know if you solved your problem and what was the solution
    regards
