scorpion411
- Nov 26, 2019
Hello, i am new to CAD design and machining and i have some general questions because i want to prepare a 3d model for the machine shop for CNC.
Lets say that i want to design a hole of 15mm with tolerance +0.00 to +0.10mm and a 15mm shaft with tolenrance -0.00 to -0.10. What dimensions will i have to design in the 3d model? Should both be 15mm and refer the tolerances or should i design for example 14.95mm for the shaft and 15.05mm for the hole?
Or in other words what dimensions the CNC machine "see" from the 3d model as to generate the Gcode? Does it take into account the tolerances or these are only for the machinist?
Thanks!!
Thanks!!
