Speedie
Stainless
- Feb 24, 2009
- Midwestern MN/Wi USA
Well double column any way. Nice Z axis on those
HDC-3-5AX | 5-Axis Double-Column Mill | HSK-Taper Mill | Large-Platform CNC Mills | Vertical Mills – Haas CNC Machines
Travels S.A.E METRIC
X Axis 150.0 in 3810 mm
Y Axis 106.0 in 2692 mm
Z Axis 43.0 in 1092 mm
Spindle S.A.E METRIC
Max Rating 60.0 hp 44.7 kW
Max Speed 6000 rpm 6000 rpm
Max Torque 110.0 ft-lbf @ 3000 rpm 149.0 Nm @ 3000 rpm
Taper HSK-A100 HSK-A100
B Axis - Tilt S.A.E METRIC
Travel ±120˚ ±120˚
Max Speed 68 °/sec 68 °/sec
Max Torque 2100 ft-lbf 2847 Nm
Brake Torque 1239 ft-lbf 1680 Nm
C Axis - Rotation S.A.E METRIC
Travel ± 245 ° to 245- ° 245 ° to 245- °
Max Speed 170 °/sec 170 °/sec
Max Torque 2240 ft-lbf 3037 Nm
Brake Torque 2000 ft-lbf 2712 Nm
Table S.A.E METRIC
Length 153.0 in 3886 mm
Width 49.0 in 1245 mm
Max Weight on Table (evenly distributed) 10000 lb 4536 kg
Between Columns 75.0 in 1905 mm
Bridge Clearance 51 in 1,295 mm
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 50+1 50+1
General S.A.E METRIC
Coolant Capacity 95 gal 360 L
Air Requirements S.A.E METRIC
Air Required 4 scfm @ 100 psi 113 L/min @ 6.9 bar
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Air Pressure Min 80 psi 5.5 bar
Travel ±120˚ ±120˚
Table S.A.E METRIC
Type SMTC SMTC
Capacity 50+1 50+1
