New machine video
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
    Feb 2003
    Alabama
    523
    24
    281
    Default New machine video
    Ok, here it is: http://youtu.be/RNgCNQqJPFw
    Doosan Lynx 220 LYA with LNS barfeed and chip conveyor. "Installed" in early September. Got training on it more than a month later, but didn't know what questions to ask at the time. I did get my live tools ordered and delivered. Machining isn't my day job, so I've got a lot of other obligations that take up the majority of my time.
    I just went ahead and tackled the hardest part I've got. Hopefully my other parts will come together quicker! I spent the better part of the last two months trying to a) crack the code on Fanuc, b) learn mill/turn, c) figure out how to get the barfeeder to do what I thought it should, and d) redesign my parts so they would be make-able on my Doosan. I also had to order some custom tooling that took ~5 weeks to arrive. During the 2nd week of January, both my slitting saws and step drills showed up. I needed custom slitting saws, because 2-3/4" diameter saws usually have a larger mounting hole than would fit in the 1/2" mandrels that fit in my live tools. I also needed custom carbide step drills because I've used up all the positions in my 12-tool turret. Carbide so no spot, step so I have a clearance hole (.199"), and the correct diameter (.175) for a 70% 10-32 form tap.
    I have to give a huge "Thank You" to Tony and the other contributors to the Macro Programming Fundamentals sticky. It is no exaggeration to say that it changed my machining life. I ended up buying Peter Smid's book on Fanuc macro's and it helped fill in the blanks. For my part in the video above, back in the olden-days, it took me four operations to complete it. One on my Haas TL-1 lathe, and three on my Haas VF-2 mill. My part has a stepped bore...1" of it is 1.002" diameter, and the other 1-1/8" is anywhere between 0.805" and 1.030" dia. Previously I hand-jammed each size as required to do the bore on the TL-1. For each size I had to do on the TL, I had to post two different programs from my CAM to finish it up on the VF-2. What a pain! I probably have over 300 different programs for the different part sizes. Now at the top of my main program on the Doosan, I input part size and the number of parts I want made. That's it. Hit the "go" button. Macro variables, math, and 18 different sub-programs do the rest.
    Programming my part is a bit more complicated than it seems on the surface, as there is a transition point where the stepped bore on both ends is equal. Since the larger opening needs to be toward the turret, having a part size LT or GE 1.002" affects: the side of the part the screw holes are on; how deep the bore and subsequently the cross slit are; alignment slots are different lengths; chamfer is different (back chamfer, chamfer between the steps of the bore, external chamfer), etc. I especially enjoyed working out how to strip out the numbers from the part size input at the beginning of the program so I could engrave it on the part! What an education working through this one! Total machining time on this part is probably only a couple minutes faster than before...but with no handling, no deburring, and no re-writing and re-posting programs for a new size, it's like a lifetime.
    I love watching machine videos. Hopefully you like this one. You've earned it answering all my stupid questions (even if you didn't know it), and giving guidance. I'm all ears for any hints for making this part even better!
    Eric U
    Sep 2002
    Lawrenceville GA USA
    6,271
    848
    1370
    Nice....thanks for sharing.
    Charles
    Dec 2007
    louisiana
    140
    87
    Nice work! I think the Lynx 220 allows you to half index your turret to add more tool stations in case you need more. I have quad tool blocks on my Mori NL2500SY and that frees up a few stations. Wasprogramming the macros difficult to get a handle on?
    Feb 2013
    Auburn, WA
    696
    43
    826
    Great video. Putting that thing to work!
    Feb 2003
    Alabama
    523
    24
    281
    The Lynx actually does have a "24" position turret. One 3-boring-bar block came with the machine, but it doesn't have a way to put a back-plate on it for through-tool coolant. At one time I was trying to run three 5/8" bars, and almost nobody makes 3/4" x 5/8" boring bar bushings. I buggered up my 5/8" boring bar and went with the 1/2" in the video, so I guess that isn't as much of an issue anymore. The 3-bar block is also pretty short and I like the idea of having 3-3.5" of boring bar supported by the bushing. The little 3/4" bushings are only around 1.5" long. I also have a half-position square shank tool holder, but clearance issues kept me from using it for the turn-face and parting tools. Anyway, step drill already in hand so no need to change now.
    The macro's weren't as bad as I thought they might be. I did a short stint as a computer programmer, so some of the logic was still stored away in the dark recesses of my mind. After reading through the whole Macro Programming Fundamentals sticky, and Peter Smid's book. I was reasonably equipped to give it a try. I did have some teething problems, but I got most of those sorted out in a day or so. Overall, my 18 sub-program program evolved into it's present shape and form. My initial one was probably only 10 subs (before saws and drills showed up). Give it a try!
    Eric U
    Dec 2007
    N.E. oHIo, USA
    2,357
    1373
    Very nice work!
    Rex
    Dec 2007
    Southeastern US
    6,401
    845
    2808
    Good Job. Nice parts too.
    Apr 2009
    CANADA
    Ontario
    1,555
    534
    486
    Very nice looking part. Good job. Nice machine.
    May 2007
    Massachusetts
    1,432
    479
    1229
    Bravo !! I would like to know more about what you are doing, You said machining is not your day job. Is this your own product ? If you are doing this on the side while holding another full time gig that is great. I loved the video you have done well.
    Ron
    May 2008
    SOUTH AFRICA
    1,626
    1191
    667
    Great Job and great video!
    One question about the tapping... Why do you have your R plane set above your return height? No giving you crap just a question
  11. #11
    Feb 2003
    Alabama
    523
    24
    281
    Quote Originally Posted by overflow machine View Post
    Ron
    My own product. My real job is the Army. I'll retire in a few years and am working on my "life after the Army" plan.
    Eric U
  12. Likes Captdave, Orange Vise, Hertz, Rstewart, exkenna liked this post
  13. #12
    Feb 2003
    Alabama
    523
    24
    281
    Quote Originally Posted by NAST555 View Post
    Just an example of me not knowing Fanuc. The CAM spit out the tapping code and I haven't dug into it enough to get it right. I'll fix it in a bit. Today's job is to make my next part program.
    Eric U
  14. Likes NAST555 liked this post
  15. #13
    May 2012
    Pittsford, NY
    1,063
    732
    685
    Thank you for turning it in brass without coolant. Made what was going on much clearer than the usual flood coolant videos....
  16. Likes Jashley73 liked this post
  17. #14
    Nov 2005
    Maryland
    8,201
    746
    1105
    Hi Eric,
    Nice video.
    Two suggestions
    1) Add a small light at the camera position pointed toward the work. Much of the subject is in shadow.
    2) Follow through with removing the parts so we can see what they look like.
    - Leigh
  18. #15
    Sep 2002
    6,271
    848
    1370
    Quote Originally Posted by The real Leigh View Post
    Hi Eric,
    Nice video.
    Two suggestions
    - Leigh
    He did ?
    Charles
  19. #16
    Feb 2008
    Paradise , California
    1,843
    264
    537
    great video and very nice looking part and programing !
  20. #17
    May 2004
    Ridgefield, Wa USA
    612
    202
    74
    I have a question I have no idea that is why I am asking. In some of the views it seems other tools get close to the turning chuck does the machine know how close it can get to stop a crash or do you have to know how close another tool is when doing an operation? If the machine knows and has a limit set how do you program for this type situation.
    Thanks for the video it was interesting to watch. Nice looking part.
  21. #18
    May 2008
    SOUTH AFRICA
    1,626
    1191
    667
    Quote Originally Posted by gundog View Post
    Yup yup So I think from what I can see that he programs how I do. Make sure your other stuff does not get eaten by that angry chuck.
  22. #19
    Apr 2009
    CANADA
    Ontario
    1,555
    534
    486
    Hi Eric,
    Nice video.
    - Leigh
    You have to watch the whole video, lol.
  23. #20
    Jun 2012
    Michigan
    4,979
    4538
    2999
    Stop being a scaredy cat and turn that rapid on full!
    Also, why clamp the R's at 3,000?
  24. Likes RoboMiller liked this post
