Look on the end view and you will see 2 hand holes for a removable panel at left (machine front). Remove that panel for access to the table for long items, another panel on other end of enclosure. I drilled 12)96" long W9 I beams on my VTC300C and had a 10' section of roller conveyor bringing them into the machine. Roll in, flip into vises, drill loads of holes, roll out and repeat.
For sure I was not happy, but not very worried after seeing how the factory wraps these machines. Only holes in the plastic were for tie down chains, holes just enough to get chain through. Pic shows transport getting ready for crane loading.
That chain may or may not be touching the rail, for sure not touching the screw. Chain goes through one of the 2 round tie down holes in the base, chained to forks. That may just be the excess chain length looped where it is not dragging. You can see other hole on right side of base. And the Mazak Rep was there for the whole time watching things closely. It was a very tight fit getting in and we had to remove the side steel (building) from one side and pound down the welded on I beam flange that held that side of the jamb. One rigger was holding a piece of cardboard as front sheet metal was rubbing on the other steel jamb. No scratches. Just a but of slightly bent metal where one section snagged the flange before I flattened it. Not a scratch and I can easily bend that bit back.
We got the building closed up by 5:30 and called it a day. I had been at it since 6 that morning. Yesterday I finished re installing the OH door top rails along with the parts that supported the jack shaft. Wound the spring, made final adjustments, and applied all new weather stripping. Today I am fluffing off. I had to do household trash run to company dumpster, so went in to walk around and look at the new machines.
Tomorrow I start cleaning protective goop off.
