I am machining an aluminum block. Due to the radius on the corners I am trying to machine 5 sides in one setup.
First attempt was with a long (4" long) 1/4" high helix endmill. I roughed it out in .250 DOC passed and all was great. I had the finish pass to cut full DOC (2.5") contour (fusion toolpaths, .010" WOC .002" chip load. All looked good until the endmill dug in and broke rounding the 3rd corner....
I am open to any ideas, I don't really want to try the long endmill again $$, I was too cheap to go with a large diameter long endmill as the cost seems exponential.
I am considering going with an insert endmill (I have APKT 1003 inserts that run well on aluminum).
Surface finish may not be critical, at first these were to be anodized but now I may powder coat the exterior.
Would this be a reasonable endmill? 5/8" 90 Degree End Mill OAL 7-7/8” APKT Insert
The aluminum is cast, but T5 hardened, not gummy at all and high helix endmills and WD-40 got smooth finishes on the cap ( the cap in the picture was etched harshly (trying out finishes)
