New to me Hitache Seiki 3NE-300 Lathe with Fanuc 5t Control. Could you some pointers
wolfenstien
Oct 6, 2009
Maine
Good Evening Gents,
This past weekend I took a trip to look at a CNC lathe. I've hemmed and hawed at a lot of cnc mills and lathes, but the price was right so I put down some money and assuming she fires up and runs as expected I'll be pulling this machine home. I've never owned a true cnc machine. I've built a cnc router in college. And I picked up a Bridgeport Boss CNC mill awhile back. Both machines run Mach3. The Boss has actually made a few parts and seems to work ok. Kinda disappointed with the Mach3 control but I digress this thread is about the new (to me) lathe. I expect the age of the lathe is somewhere around 1980 (a good 10 years older than me :) )
Supposedly the machine has manuals, but they were in the back cabinet and the door was against a post and couldn't be opened so I currently don't have any literature on the machine. It is a Hitachi Seiki 3NE-300. 10 Hp lathe with hydraulic tailstock, 12 position turret and a small 6" hydraulic chuck. Shop owner was to busy with end of the year work to get to the machine, but wrote me out a bill of sale guaranteeing full power up with opportunity for an inspection prior to Jan 31st. Worked out well for me. I gotta get a space cleaned out for it and run power over etc. My biggest concern is the 5T control.
Luckily I have a friend at work who seems to remember using a 5T way back when and is willing to come over and start walking me through it when its ready. I got so excited when I came home the first thing I did was pick up an ADR BTR (Behind the tape reader) on ebay. Paid a little less than $150 for the BTR card so I think that was a good deal. From what I have read it should make the control much more usable. I'm thinking I'll try onecnc/cnclink for the softward side.
Most of what I am looking for out of this thread is what to expect from the control. I have read that the 5T doesn't read decimal points in dimensions. Is this correct? I was also wondering if anyone had an idea of which canned cycles will and wont work. Will G71 work? I really don't know much about programming a lathe, but the before mentioned friend from work is a bit of a guru in my opinion. He tolerates me bugging him during lunch breaks about simple programs and is a wealth of knowledge and seems quite willing to disperse that knowledge. Figured I would try to tap you guys as well though.
There are about 1/2 dozen threads on here with 5T controls, but they don't get to in depth. Sounds like DOCCNC has some dvds on them, but they look a little expensive for the home shop startup guy.
Anyway. Any input on either the machine or the control is much appreciated. I find a astonishing shortage of info online for the Hitachi Seiki machines. Thank you all.
The other place has a Funuc 5T sub forum. Rhymes with see n see bone dot com.
The only person here that mentioned he has a Fanuc 5T that I know of is Garwood.
Brent
Good Evening Gents,
All of the Multi-repetitive cycles (G71 - G76) are available with the 5T control. They are options, the same as they are on more modern controls, but most machines were supplied with them. G71 Type I is the version supplied; Type II wasn't in existence when the 5T was introduced.
Its correct that the 5T control doesn't tolerate decimal points. I supply software to my clients who have 5T controls and the Mill equivalent, that displays the program with decimal points included on the PC screen (easier to read), but converts the data to the format that the 5T requires as its drip fed to the control.
Regards,
Bill
I have a 5T on my 3NE300 and 4NE400
I can post some sample programs I use if ya want
Bill
Bill
Does the 5T use G50's? It would be interesting to look at some of your 5T example programs. Other than single line canned cycles its probably not too much different than the i control. Might help the OP...
Brent
Yep, I run a 5T Mazak almost everyday. Mines 1979, 4 years older than me. Mine had an ADR BTR installed when I bought it. The ADR folks are good people. Helped me get the RS232 setup right when I bought it.
No decimals, no work offsets, no screen. Get used to reading numbers from right to left.
My 5T has been rock solid reliable. The only issue I have had is running from memory. Sometimes it would lose some Z distance, like inches. I run mine straight from the BTR instead of loading into memory first now. No problems.
When you get it set up you'll have questions. Ask away. When you run it your butthole will be puckered with no display. After awhile you kinda get used to it. Totally new parts/tooling are always a bit scary.
Brent
I don't have any programs here I guess
this is the Smart Cam TMP file
@START
#ONBLKM98P100L10
M30
#SAFBLK#SPMODE#MOVX#XPOSZ#ZPOST#TOOLS#SPEED
T#TOFFM8
#NEXTPT
#MOVX#XPOSZ#ZPOS#SPNDL
@TOOLCHG
#SAFBLK#SPMODE#MOVX#XHOMEZ#ZHOMET#TOOLS#SPEED
T#TOFFM08
#NEXTPT
@END
#SPOFF
G00X#XHOMEZ#ZHOMET#NTOOLM09
M01
M99
#OFFBLK
N9999G28X0Z0
N9991G50X80000Z113000S4000
N9992M30
@STPROF
<#MOV><X#XPOS><Z#ZPOS>
@RAP
@LINE
<#MOV><X#XPOS><Z#ZPOS><F#FEED>
@ARC
<#MOV><X#XPOS><Z#ZPOS><I#XCTR><K#ZCTR><F#FEED>
@FXD1
G76X#XPASSZ#ZPASS<I#XOV>K#V1D#V2F#FEEDA60
@FXD4
G33Z#ZPASSF#FEED
M04
G33Z#ZPOSF#FEED
@TAILIN
M05
M12
G04P250
M03
@TAILOUT
M05
M13
M03
@OPEN
M05
M69
G0Z#ZPOS
M68
G4P200
@STOP
M0
That is the Smart CAM post processor not a program
You still use SmartCam??? Back in the day it was pretty good, but after all the ownership changes they seemed to lose direction and got left in the dust.
@yardbird, Yes, the 5T can use G50s. I did on the one I ran back in the late 70s-early 80s. Then your offsets are just used to adjust for tolerance and wear. I pretty sure it would have been possible to set each tools position as an offset but that would have big numbers in the registers and if you fat fingered in a wrong value........
Had 5T lathes for years. You really need to get your head around the G50. When you change tools you need to call G50 for each tool as the wear offsets only go 100mm. I would only suggest using these for tolerancing.
If you send me a pgm you make I can edit it for you no prob.
Its really only G50X....Z....(This usually home in X and I generally used Z 200mm from the face of your part.)
T0101
G00G40 X (must be the same as last G50) Z (must be the same as last G50)
T0202
G50X....Z.... This G50 is the position that Tool 2 is from X 0 Z 0 on your part.
And repeat for each tool.
NOTE. If you pull the turret forward or move in Z to change or check tips between parts you MUST manually drive the turret back to the original start position. (Home in X and Z200 from the face of the part.)
There are many ways you may choose to set as a pgm method but basically you NEED to remember that wherever the tool is when the pgm reads the G50 the machine thinks that is where it is. BIG crashes if you are not diligent with your checking. BTW thes old electronics and DC motors take a few seconds to pull up when you crash so damage is never small.
Cheers
Ya I'm old still running it on a 486-66 with windows 3.1 lol
Still works for me all that matters ;)
I'm sure I will get bashed for my poor programing skills but here is the code
N100G97G00X50000Z30000T0100S1000
N101T0101M8
N102G00X15001Z1000M03
N103X14001
N104G01Z-38810F40
N105G00X14501Z1000
N106X13501
N107G01Z-38810
N108G00X14001Z1000
N109X13001
N110G01Z-38810
N111G00X13501Z1000
N112X12501
N113G01Z-37450
N114G00X13001Z1000
N115X12001
N116G01Z-37450
N117G00X12501Z1000
N118X11501
N119G01Z-37450
N120G00X12001Z1000
N121X11001
N122G01Z-37450
N123G00X11501Z1000
N124X10501
N125G01Z-37450
N126G00X15000Z1000
N127X11100Z50
N128G01X-520
N129X8389
N130G03X8898Z-55K-360
N131G01X9939Z-576
N132G03X10150Z-831I-255K-255
N133G01Z-37450
N134X11920
N135G03X12740Z-37860K-410
N136G01Z-38810
N137G00X15000Z1000
N138X50000Z30000
N200G97G00X50000Z30000T0300S1300
N201T0303M08
N202G00X11000Z0M03
N203G01X600F30
N204X8209
N205G03X8704Z-103K-350
N206G01X9745Z-623
N207G03X9950Z-870I-247K-247
N208G01Z-37490
N209G02X9970Z-37500I10
N210G01X11740
N211G03X12540Z-37900K-400
N212G01Z-38800
N213G00X50000Z30000
N300G97G00X50000Z30000T1100S500
N301T1111M08
N302G00X10600Z2000M03
N303G76X9100Z-9000K500D100E71428A60
N310G00Z2000
N311X50000Z30000
N312M05
N313G00X50000Z30000T0100M09
N314M30
N9999G28X0Z0
N9991G50X89556Z93000S3000
N9992M30
Program 2
N10M98P100L10
N11G97G00X70000Z60000T0100
N12M30
N100G97G00X50000Z30000T0100S2500
N101T0101M8
N102G00X10000Z0M03
N103G01X-300F40
N104X7524
N105X8000Z-238
N106Z-3150
N107G00X50000Z30000
N200G97G00X50000Z30000T0200S2500
N201T0202M08
N202G00X0Z1000M03
N203G01Z-2500F80
N204G00Z1000
N205X50000Z30000
N300G97G00X50000Z30000T0400S2500
N301T0404M08
N302G00X6000Z500M03
N303G01Z0F20
N304X5582
N305X5200Z-191
N306Z-3070
N307G00X5000Z500
N308X50000Z30000
N400G97G00X50000Z30000T0900S2500
N401T0909M08
N402G00X9000Z-2500M03
N403G01X8000F20
N404Z-2800
N405X7600Z-3000
N406X4600
N407G00X9000
N408X50000Z30000
N500G97G00X50000Z30000T1000S2500
N501T1010M08
N502G00X0Z-2000M03
N503M05
N504M69
N505G0Z500
N506M68
N507G4P200
N508X50000Z30000
N509M05
N510G00X50000Z30000T0100M09
N511M01
N512M99
N9999G28X0Z0
N9991G50X89556Z113000S3000
N9992M30
N101T0101M8
N103X14001
N104G01Z-38810F40
N105G00X14501Z1000
N106X13501
N107G01Z-38810
N108G00X14001Z1000
N109X13001
N110G01Z-38810
N111G00X13501Z1000
N112X12501
N113G01Z-37450
N114G00X13001Z1000
N115X12001
N116G01Z-37450
N117G00X12501Z1000
N118X11501
N119G01Z-37450
N120G00X12001Z1000
N121X11001
N122G01Z-37450
N123G00X11501Z1000
N124X10501
N125G01Z-37450
N126G00X15000Z1000
N127X11100Z50
N128G01X-520
N129X8389
N131G01X9939Z-576
N133G01Z-37450
N134X11920
N136G01Z-38810
N137G00X15000Z1000
N138X50000Z30000
N201T0303M08
N202G00X11000Z0M03
N203G01X600F30
N204X8209
N206G01X9745Z-623
N208G01Z-37490
N210G01X11740
N212G01Z-38800
N213G00X50000Z30000
N301T1111M08
N310G00Z2000
N311X50000Z30000
N312M05
N314M30
N9999G28X0Z0
N9992M30
Program 2
N10M98P100L10
N12M30
N101T0101M8
N102G00X10000Z0M03
N103G01X-300F40
N104X7524
N105X8000Z-238
N106Z-3150
N107G00X50000Z30000
N201T0202M08
N202G00X0Z1000M03
N203G01Z-2500F80
N204G00Z1000
N205X50000Z30000
N301T0404M08
N302G00X6000Z500M03
N303G01Z0F20
N304X5582
N305X5200Z-191
N306Z-3070
N307G00X5000Z500
N308X50000Z30000
N401T0909M08
N403G01X8000F20
N404Z-2800
N405X7600Z-3000
N406X4600
N407G00X9000
N408X50000Z30000
N501T1010M08
N502G00X0Z-2000M03
N503M05
N504M69
N505G0Z500
N506M68
N507G4P200
N508X50000Z30000
N509M05
N511M01
N512M99
N9999G28X0Z0
N9992M30
Sorry neither of these pgms will work.
1. No G50
2. Tool offsets need to be canceled eg T0100 Before the next tool is called.
Otherwise tool offsets are added.
On a T5 when a tool offset is called and then not cancelled it is added to the the next tool called. And without a G50 all tools would need to be same X & Z value.
Again.....be Very careful with pgms for a 5T
N101T0101M8
N103X14001
N104G01Z-38810F40
N105G00X14501Z1000
N106X13501
N107G01Z-38810
N108G00X14001Z1000
N109X13001
N110G01Z-38810
N111G00X13501Z1000
N112X12501
N113G01Z-37450
N114G00X13001Z1000
N115X12001
N116G01Z-37450
N117G00X12501Z1000
N118X11501
N119G01Z-37450
N120G00X12001Z1000
N121X11001
N122G01Z-37450
N123G00X11501Z1000
N124X10501
N125G01Z-37450
N126G00X15000Z1000
N127X11100Z50
N128G01X-520
N129X8389
N131G01X9939Z-576
N133G01Z-37450
N134X11920
N136G01Z-38810
N137G00X15000Z1000
N138X50000Z30000
N201T0303M08
N202G00X11000Z0M03
N203G01X600F30
N204X8209
N206G01X9745Z-623
N208G01Z-37490
N210G01X11740
N212G01Z-38800
N213G00X50000Z30000
N301T1111M08
N310G00Z2000
N311X50000Z30000
N312M05
N314M30
N9999G28X0Z0
N9992M30
Program 2
N10M98P100L10
N12M30
N101T0101M8
N102G00X10000Z0M03
N103G01X-300F40
N104X7524
N105X8000Z-238
N106Z-3150
N107G00X50000Z30000
N201T0202M08
N202G00X0Z1000M03
N203G01Z-2500F80
N204G00Z1000
N205X50000Z30000
N301T0404M08
N302G00X6000Z500M03
N303G01Z0F20
N304X5582
N305X5200Z-191
N306Z-3070
N307G00X5000Z500
N308X50000Z30000
N401T0909M08
N403G01X8000F20
N404Z-2800
N405X7600Z-3000
N406X4600
N407G00X9000
N408X50000Z30000
N501T1010M08
N502G00X0Z-2000M03
N503M05
N504M69
N505G0Z500
N506M68
N507G4P200
N508X50000Z30000
N509M05
N511M01
N512M99
N9999G28X0Z0
N9992M30
Good Morning all,
Thank you for all the replies. I gotten mixed messages from different people. Some say working with a control this age is just not worth it, but others say there is nothing wrong with the control and as long as you learn to work with it, then it can be quite usable. Maybe not particularly user friendly, but usable. No matter what anyone says I'm still a little giddy to have a real cnc lathe. Probably won't get it moved and under power till late in January.
BMP, if you have this exact machine with the same control is it likely that the parameters will be the same? The machine has been powered down for about a year so its possible they are gone. I hope not, but we shall see. Not sure how I'm going to proceed if there parameters are gone. Can't really do an inspection without those.
Oh yeah I was also meaning to ask. I have seen two different sets of specs for the 3ne-300 machines. Some have a higher speed spindle speed (6000RPM I think) with a smaller through bore somewhere around 1.7" diameter and the others have around a 3500RPM max with a 2.0" Spindle. Which one do you have? I am pretty sure that the one I am getting is the higher speed smaller spindle bore model. I think the large spindle model also had 8 stations in the turret vs 12 on the high speed. I cannot confirm these specs though.
Again thanks for the support and input. Really looking forward to seeing how this turns out.
Good luck with the 5T, there are still a lot around and working.
I trained the class for Fanuc in Chicago back then, the 6T came out in about 1980, it was quite an improvement for those days.
The 5T:
No screen at all.
No decimal point, all dimensions, also feedrate written lke: X30000 for X3.0, F100 for F.01.
S500 was automatically RPM, no G96 for SFM.
No Program Number, all programs start with block numbers. No noseradius comp.
Quite reliable.
This is Heinz at doccnc.com, good luck.
1. No G50
I knew someone would bash my program
Sorry to say that is a working Program
G50 is on line N9991 I just use it in the morning to set zero point
Offsets are canceled when next tool is called N200G97G00X50000Z30000T0300S1300
Dry run is your friend
I have had this machine scene 88
The 5T:
No screen at all.
Quite reliable.
Hmm mine uses G96 and G97
Bad thing only 16 tool offset's
Good Morning all,
My 3NE is 4000 rpm. 1 3/8 thru 12 station turret
4NE is a 3200 gear head 2" thru 12 station turret
I didn't know they had others
I have put a spindle in this machine don't remember them asking which one I had.
Parameters should still be there battery keeps them there
Mine has 3 AA's for parameters and 3 D's for program
Change them only with the power ON
Cheers
This is why I only use G50 to set zero point from machine zeros
No need to remember where you are at
I use tool offsets to set from the G50 zero
My G50 X zero is the distance from machine zero (G28 X0 Z0) and center of boring tool blocks. That number never changes. (unless the encoder is removed for cleaning or replaced)
G50 on Z changes depending on tool and part length
