You don't want good stainless, not sure what you call it but over here theres a stuff that goes as chromeweld, its bellow 304 as stainless corrosion resistance goes, but its designed for corrosion and wear resistance, its used a lot to line chutes and such, has a lovely smooth finish and stuff naturally slides on it a treat, cost wise its cheaper than mild steel when you factor in the additional costs of paint too. Would be just the stuff to make coolant tanks, auger chutes, enclosures and way covers out of.
In the food industry everything is bare stainless so its easy to keep clean, really don't get why this trade is so different.
Hong Kong, sheet stainless will be used to wrap reinforced concrete columns as a cheaper finish than better concrete or their old standby - a near infinite count of itty-bitty tiles.
Downside it the air is so polluted - mayhap from factories upriver MAKING "cheap stainless" that it ain't "stainless" for very long, gradually goes a tinge brownish!
Payback is a Mother.....
But yeah. "Wear" plates, Telco rack "extras", or heat-shields for the kitchen cookers, drop into a shop on Reclamation Street between Mong Kok and Yau Ma Tei with a sketch in either Inch or Metric units, walk out a few minutes later with neatly de-burred sheets, edges wrapped and taped for a taxi or underground rail trek. It's priced off a freight scale, computed at so much a ton, no extra fees for cutting, de-burr, nor wrapping.
And you don't need even ONE word of Chinese to do the deal.
Steel and sketch speak a universal lingo. You just point a finger at which thickness, alloy, surface-finish suit the needs of the hour, and they fire-up the cold saw or shear.
You need a custom size of noodle-boiler, bakery or fryer pan? Nuther guy, back street in Wanchai with an English wheel, pressure welder, and a lot more odds and sods of gear will make you one to shape and size while you watch, weld on a handle "seamless" for easy cleaning, ELSE rivet it, your choice.
His Grandaddy was probably a "tinsmith", great G'G' G'Dad Copper.
Not he. Stainless, now.
