manualmachinist
Stainless
- Oct 5, 2012
- Battleground, Washington
We got a VMC about a year ago, and I’ve been putting taps in ER collets but I’m finding it a PITA to keep changing them every time I need a different tap size.
I do a variety of job shop shot run and one offs.
I’m considering getting a couple of Techniks brand CAT Tension / Compression tap holders that use the ANSI tap collets.
BT Tension / Compression Tap Holders
So, I should be able to set up so ERs with appropriate drills for each tap and not have to change out the drills and collets.
I would like to be able to set up a tool library in Fusion 360 for tapping that would use the same tool number but with different offsets when they post.
So, I should be able to just change the ANSI collet with the correct size of tap and the offset will already be set.
How do you guys do it? Does this sound feasible?
