corednc
- Sep 3, 2019
- East Coast
TLDR: New DNC product, can connect your machine to your network through its PCMCIA port, USB port, or floppy drive. It has advanced features like the ability to edit Excel files directly from your control. We have a zero obligation, zero cost preorder in progress, if you sign up in the next 2 weeks we will send you a discount code when we launch. Preorder | corednc
I wanted to network my machines but the options were either nonexistent or expensive so I decided to create a solution that works with most machines made in the past 2+ decades. The PCMCIA to ethernet/wifi is the best part, I can now connect my FANUC machines to my network and not deal with rs232 transfers.
I am on here a lot so feel free to ask me anything about the device.
This device plugs into the USB or PCMCIA port on your machine and allows you to transfer files to and from your computer over your wireless or wired network to your machine. This device works without installing any drivers so it works with any machine that reads from or writes to a PCMCIA ATA card or a compact flash to PCMCIA converter, a USB memory device or a floppy drive.
There are currently 6 versions of this device
USB to Ethernet - $400
USB to Wifi - $400
Floppy to Ethernet - $450
Floppy to Wifi - $450
PCMCIA to Ethernet - $400
PCMCIA to Wifi - $400
The device is easy to use simply fill in the network connection details and when connected you can simply drag and drop files from your computer to the device like you would with any network folder. You can read from and write to the device which has about 8gb of internal storage and the data transfers are fast.
This device also has some advanced features that allow you to do things like edit Excel files directly from your control. For example adding the 4 lines below after probing a bore allows you to open up an Excel file and write the dimensions of that bore to the Excel file, the file is then easily accessible over your network. See here for a detailed explanation: Adv. Features | corednc
N1000 DPRNT [XCROFL*BEARINGS*XLSX]
N1010 DPRNT[XCROSHT*BORES]
N1020 DPRNT[XSETCELL*A*/2*#188]
N1030 DPRNT[XSAVE]
There are a plenty of commands available so if you want to do things like track cycle times you can easily put timestamps in the Excel file and have excel calculate the difference for you.
Right now we are having a preorder, this is a zero cost, zero obligation preorder, we just want to know what kind of demand to expect and how many units to manufacture before our launch date. If you are interested please sign up here Preorder | corednc and as a thank you we will send you a discount code when we launch.
USB to Wifi - $400
N1030 DPRNT[XSAVE]
