New Speed and Feed Calculator - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21
    Sep 2021
    New York
    A lot of good data here, good job. If you need any Mitsubishi data hit me up, they have some new grades not listed.
    A good tap chart with thread percentages listed for different tap drills would be awesome, especially STI taps.
  2. #22
    Nov 2002
    3,411
    2122
    898
    Quote Originally Posted by ericspencer View Post
    Hello friends,
    I had been working hard over the past few months to distill all my knowledge into an online tool that will provide Speed, Feed, and Carbide Grades recommendations based on many factors.
    Speed and Feed Calculator - FREE - Speeds & Feeds Calculator (20+ params!)
    I hope you will find it useful.
    I would really appreciate getting more feedback from the field about bugs and new features that you would like to see coming in the future.
    Many Thanks,
    Eric Spencer
    Techincal Data for the Machining Industry - Machining Doctor
    It worked (although sluggish) with Firefox 91.
    Nicely done. Thank you.
    Doug.
  3. #23
    Aug 2008
    Paso Robles, CA
    194
    78
    36
    Turning Page 4, the calculated IC [inch], seems to actually be a [mm] dimension.
  4. #24
    Jun 2012
    Michigan
    6,267
    5862
    4014
    It's a little cumbersome to use, but your numbers are way off.
    1/2" end mill 1.2 depth of cut,.05" setpover in 4150pht. Set it to aggressive and your numbers are at about 1/2 of the speed I would run it at.
    It's not a bad start, but it needs work.
    Oh and ditch the popups, that will deter people immediately.
  5. #25
    Aug 2006
    montana
    419
    256
    169
    I use a horizontal mill with HSS cutters, you don't address them
  6. #26
    Oct 2021
    ISRAEL
    13
    5
    Default Will be fixed
    Quote Originally Posted by David Ferguson View Post
    Thanks, you are correct. It needs some digging to fix. I will add it to my To-Do list and fix it soon.
  7. #27
    Oct 2021
    ISRAEL
    13
    5
    Quote Originally Posted by Mtndew View Post
    1) Did you set aggressive for both cutting speed and chip load?
    2) How many teeth/flutes did you set?
    3) With both set to aggressive and 4 flutes I get 3760 RPM with 60 inch/min
    4) What did you get and at what numbers would you run it?
    Eric
  8. #28
    Oct 2021
    ISRAEL
    13
    5
    Quote Originally Posted by ronf View Post
    Thanks for the feedback!
    I added to my To-Do list to add an option to choose HSS/Carbide for solid carbide endmills and drills.
