New (Used) Machine - Fadal 3016
Results 1 to 15 of 15
    Nov 2010
    Tustin, CA
    383
    226
    113
    Default New (Used) Machine - Fadal 3016
    It's been a very busy weekend but finally brought my Fadal 3016 home. I purchased one of the 3016s for sale by Freds on the classifieds here. It was 100% as disclosed and I'm extremely happy now that it's all set. I organized rigging and transport from down here though a friend and every worked out perfectly. I really wanted to get up to the Bay Area to check it out in person (just because, not because of concerns), but just couldn't make the time. Freds co-worker that I dealt with was awesome over the phone and e-mail and really helpful.
    This is a pretty big jump for me and is replacing an older drill/tap machine with a Fanuc control. It was a great machine to start with, but ultimately just needed more than what it could offer (which I started finding out after I purchased, as I knew very little about cnc at the time).
    I shoehorned this thing into my garage with about 1/2" clearance. It helped that there are holes in the casting for lifting bars so the forks weren't under the machine. I removed the Z servo, unbolted the cable tracks and put to the side and removed the fan hat for the spindle motor.
    I already had everything for supporting equipment, a 100A sub panel in the garage, wiring, compressed air and all that, so I really just had to drop the machine. It's already hooked up and working my way though learning the control.
    I can't wait to cut some parts.
  2. Likes Toolbert, Bobw, Ox, cnctoolcat, triumph406 and 4 others liked this post
  3. #2
    Sep 2006
    Abingdon, VA
    3,325
    4395
    3021
    I have a '95 3016, and they are great machines for the money.
    From a mechanical standpoint, the box-way 3016 is the most rigid machine Fadal ever built. Why?
    Well, the 3016 has the same size ways, ballscrews, and servo motors as the popular 4020. The 3016 has less spindle-casting overhang in the Y-axis direction, and with less X-axis table overhang above the saddle, it all adds up that the 3016 has to be more rigid!
    Good luck with it,
    ToolCat
  4. Likes triumph406 liked this post
  5. #3
    Sep 2008
    1,533
    977
    886
    You'll want some sort of mist collector if your running in the garage with door closed.
    I have a Royal Filtermist 1200, I wouldn't recommend it, doesn't work very well and is very noisy.
    Next time around I would get a Mistaway, much cheaper and can be ordered to run on 110VAC.
  6. #4
    Sep 2008
    1,533
    977
    886
    Quote Originally Posted by kazlx View Post
    Have you rune a Fadal before? I ran one maybe 25 years ago for a few months. When I got the 4020 evidently I'd forgotten everything I knew about the control. It took me longer than I expected to get very proficient, not sure why.
    How are you going to send programs to the mc? I the ONECNC DNC, which I think is now NCLINK. It worked better than the FADALDNC I was using.
  7. #5
    May 2011
    No. Cal.
    368
    218
    Quote Originally Posted by triumph406 View Post
    Probably stealing kazlx thunder here Machine was sold with MistAway, plus the inductive pickup and timer that turns it on only when coolant pump is running and turns off with delay. The 'box' under the tool changer in the last picture is the MistAway.
    BTW, kudos to Kennedy Rigging and Transport out of San Jose. kazlx chose them and they were superb. Had all the right gizmos to snatch the Fadal from the side to get it out to where they could approach from front/back. Did some additional shrink wrap to get it to their yard in San Jose. Then tarped it for trip down I5 to So. Cal.
    Fred
  8. Likes wheelieking71, couch liked this post
  9. #6
    Sep 2005
    Oakland, CA
    2,395
    231
    627
    I've used Kennedy many years ago and it was all good as well- good to know they are still around.
    Dan
  10. #7
    Jan 2013
    Gilbert, AZ
    5,717
    7119
    7224
    That thing looks clean as a whistle! And, holy tight squeeze! Good job getting her in there!
  11. #8
    Nov 2010
    Tustin, CA
    383
    226
    113
    Like Freds said, it came with a MistAway and is already setup through the machine to turn on with the coolant.
    Quote Originally Posted by wheelieking71 View Post
    It is exceptionally clean. I'm really happy with it. It was tight, but it went as I've seen from other posts. Really looking forward to stepping up my capabilities.
  12. #9
    Nov 2010
    Tustin, CA
    383
    226
    113
    I was using DNC4U with my old machine and it worked great. I'll continue to use it and sounds like Fred was already using it. Their programmer sent me their settings and some other info. They also had a wifi setup that I was going to try and replicate, but will probably also order the CalMotion box for it.
  13. Likes triumph406 liked this post
  14. #10
    Nov 2018
    Oklahoma
    19
    Congrats! Please keep us updated on how spinning up the machine goes. I may end up with a similar machine soon so I am excited to hear your thoughts.
  15. #11
    Nov 2010
    Tustin, CA
    383
    226
    113
    Quote Originally Posted by bisdreamz View Post
    It's up and running. I have already ran a warmup program that they left in it. Still need to level the machine and get the vises installed. I spent the last few days running wiring and hard plumbing for air to it along with an auction refrigerated dryer I picked up. Currently running on a 15hp RPC.
  16. #12
    May 2005
    CA
    1,121
    8
    280
    +1 on Kennedy as well. They moved a wire edm machine for me about 14 years ago, and the service was fantastic.
    Good looking Fadal !! Have fun with it!!
    PM
  17. Likes kazlx liked this post
  18. #13
    Nov 2010
    Tustin, CA
    383
    226
    113
    Quote Originally Posted by precisionmetal View Post
    PM
    Thanks! I would definitely use him again. Service was good, everything happened when he said it was. Truck arrived here early, Tarping and strap job was excellent. The whole deal went exceptionally smooth.
  19. #14
    Mar 2008
    vacaville ca
    389
    47
    89
    +1 on Kennedy as well. They moved our shop a few ago when we moved.
    And they got my 3016 into my garage as well.
    Glad to see you got it all in and running....
    and again if you ever need service M&M in Chatsworth, they know those
    machines inside and out.
  20. Likes kazlx liked this post
  21. #15
    Jun 2009
    138
    85
    38
    I'm excited for you, this is a huge step up from the Cobra. Love seeing how far you've come in such a short time.
  22. Likes kazlx liked this post
