Hello everyone.
So a couple months ago I started working in the machine shop at my job. I was initially another button pusher until one of the mill guys got fired. So now I am to be his replacement eventually, however i know very little about machining and G&M code programming. They have 3 Mazak mills and up until now I have been using the Mazatrol interface to do parts. Recently I wanted to try to write code in the EIA/ISO format. My first practice program I'm trying to do is a figure eight followed by a sideways "S" movement. My problem is when I go to run the program I get the alarm "806 illegal address _, 0, 0. When I try to watch the graphic tool path on the screen I get the alarm "465 EIA shape data not found". I assume it is a syntactical error on my part but I don't know what it is. I would ask my Lead but unfortunately he doesn't have the time right now. Im on a Mazak VCN 510C-II with a Mazatrol Matrix Nexus.
Here is the code:
N1 G20 G90 G17 G94
N2 T01 M06
N3 G00 X-10 Y-5 Z-5 S1500 M03 M08
N4 G91 G02 I0 J2 F.5
N5 G03 I0 J-2
N6 G02 X-5 I-2.5 J0
N7 G03 X-5 I-2.5 J0
N8 G28 Z0 Y0 X0
N9 M30
I tried with and without % and beginning and end of prog. Also tried with the "O" prog number. I appreciate all constructive criticism, even if its unrelated to the errors I'm receiving. Thanks
Here is the code:
N1 G20 G90 G17 G94
N2 T01 M06
N5 G03 I0 J-2
N6 G02 X-5 I-2.5 J0
N7 G03 X-5 I-2.5 J0
N8 G28 Z0 Y0 X0
N9 M30
