Hey guys,
My first post, I want to start by saying I'm a total newbie to machining and I wanted to dive right in and start with manual hand machining and hope to later convert my g0704 into a CNC.
First question is should I buy a table vice or clamping kit?
Second question is the T-Slots specifications state 3 @ 2.5 inch, center 1/2 inch wide, what does this mean, how do I read the numbers and select the appropriate vice or clamp.
Third I have an idea of the end mills I want, I will be cutting aluminum almost exclusively. After some research it appears a 3 flute carbide end mill would be a good fit. What is the best kind of beginners kit to purchase, perhaps I should buy something cheap because I will be breaking them since I am learning. Could you point me to a kit that is good for beginners?
Thank you guys and I look forward to learning more.
