I have been carefully reading up on lathe options over recent weeks, as my current little cnc lathe isn't very good - it can sort of do what I want, but its really time consuming to the point I think a manual lathe would be as quick.
SO i have been reading up on any cnc lathe that comes up for a good price, to check it will be an improvement and read up what people are saying about them.
A while ago two Hardinge CHNC1 came up for sale as a job lot, I had no room for the both but the price point got me interested. After reading up it seems they are perfect for the sort of work I will be doing (small motorcycle spacers/cylindrical parts) mostly in alu or delrin, and as the spindle motor isn't a monster I can more easily run it off a rotary phase converter without too eye watering a price tag (RPC cost more in the UK as there is a very small market for them, so no economies of scale)
From what I have read these lathes are solid enough with a few faults:
collet closer leaks
turret index issues (again linked to air leaks/failures in the air driven system)
Controller boards going pop
X axis motors getting worn and going pop
Another one has come up for sale, and I have come to an arrangement with the seller to hold it for when I go and see it on Monday - an small engineering shop is closing as the owner retires.
I'd welcome advice about a few points please:
As the cost of rigging is more than the cost of the lathe, and the RPC is double the price of both, the lathe itself isn't the main cost, but I have a budget and I'm really pushing it for this so any advice would be welcome.
Cheers folks!
collet closer leaks
- apart from the things I have listed, is there anything else I should look for?
- the spindle has a collet type system, am I right in thinking these can be swapped out for the odd job that may require a 3 or 4 jaw chuck? I wont be doing bigger parts much, but its handy to know I can if needed
- What size rotary phase converter should I aim for? the plate on the machine says 7.5 KW, and I understand the main spindle is 5hp
Cheers folks!
