Stevevanderloo
- Jan 29, 2012
- London, Ontario
I have an old First LC-CV305 bed mill with an OM-B control. I saw the machine run satisfactorily before purchase. Now that it is installed in my shop I have only been able to get axis movement once. When I tried jogging 30 minutes later there was no action. According to the manual for this machine, axis should be ready for movement after computer screen runs past diagnostics. No other buttons need be pushed. The only installation change I made was I by passed the 575 transfomer as my input voltage is 220VAC 3 phase. I also cleaned the HMI rotary switches.
There are no alarms, no over travel limit switches open, or emergency stop buttons pushed. All the fuses are ok. The power draw bar does not function. It won't move in jog, rapid, go home, using hand wheel or push botton.
Any suggestions as to what to look for?
