I was using the machine yesterday, started and ran OK for a short piece of work. Today, I powered the machine, turned on the controller, everything looks fine (no errors, diagnostics passed), went to Mode Select, got the usual Fault flashing, then did Reset and the machine doesn't respond with servo power-up. The Emergency Stop status message stays on screen. It's the only fault message.
I have exercised the EMO a number of times to see if there's something sticky there, no joy. I occasionally see the screen blink when I punch the Reset button, but still nothing from the servos.
Anybody out there with been-there/done-that stories or help? I assume next is likely yanking the control cover and having a look-see, but my only thoughts are either bad connection at EMO, or bad servo relay(?). I don't know a lot about this at the moment.
