partsproduction
Titanium
- Aug 22, 2011
- Oregon coast
I'm having a very hard time suddenly holding onto 2" diameter 7075 round bar for machining, and a first for us, the bar is walking out instead of heavy cuts pushing it into the collet.
Among the things I'm looking into is the possibility that the collet closer system is not working right.
If I unscrew a collet far enough that it can't squeeze in the collet nose and actuate the closer the collet's total movement is only 1/8", and I'm wondering if that's the normal movement?
The spindle liner is .025" larger than the bar, and I was told that's normal because of bent, damaged or oversized bars. My mention of that goes to the bar "Walking" out of the collet as I've seen carbide endmill shanks walk out with chatter before.
Another factor may be the aggressive high positive inserts I've been using, the theory being that they are pulling the bar as they cut. We've done this job twice before without seeing this problem.
I hardly have any hair left! If anyone could check the pull distance with a 22J collet I'd like to hear how far their machine's spindle nose, collet adapter and collet nose allows an unloaded collet to move in and out. Heck I even grooved the gripping area of the collet trying to stop this problem.
I could mount a chuck, that would hold, but as I said we've never had the problem before.
