I am trying to tram my CNC mill table because when I face mill front to back, I get a small step in the part where the face mill passes overlap. So I checked the tram of the table. At the center of the table it is within 0.0002". I then checked the left side and then checked the right. There is a left side vs. right side of table tram difference of 0.002" across using a 5" diameter tram check. It appears to be slop in the bearings when the table weight shifts.
What difference in tram do others typically see if you tram far left of table vs. far right? Do my bearings need replaced?
