wishin4snow
- Dec 17, 2018
We finally had to get rid of our last Hardinge CHNC chucker. We run a couple of jobs that we need to use an air chuck. All of our Northfield air chucks that ran in the chuckers have the threaded 5C adapter. We need to mount the Northfield to the SL-10 now to make the parts and the SL-10 has a 5C collet chuck on with the threaded nose but I am afraid that the airchuck might just unthread when the spindle stops. These spindles slow down a lot quicker than the chuckers. Is there an easy solution to this or do I need to get a spindle adapter for the Haas. We would need to switch between the air chuck and standard 5C pretty regularly.
I thought about adding a locking set screw to the assembly but I would need to drill into the 5c collet chuck.
