NPT drill size .0005 difference
Results 1 to 19 of 19
    Apr 2021
    SWEDEN
    48
    31
    Default NPT drill size .0005 difference
    Hi
    Would like to try to drill NPT drill without reamer, so the drill size for 1/4 - 18 is 7/16 = 0.4375 what if i use 0.438 drill so +.0005 .. is there going any problem?
    Thnaks...
    Jul 2015
    Wisconsin
    349
    23
    127
    No.......no no no....did I reach the minimum yet?
    Apr 2021
    SWEDEN
    48
    31
    Quote Originally Posted by MaxPrairie View Post
    Sir
    drill size 0.4375+0.0005= 0.438" instead of 0.4375"
    But i think it's not possible since the tolerance in NPT thread very tight, want to make sure
    Jul 2015
    Wisconsin
    349
    23
    127
    Half a thou oversize on the minor is not a big deal. What you should watch is the # of threads engaged to hand tight or have a plug gage to make sure tap depth is correct.
  5. Likes M Code liked this post
    Sep 2007
    Washington
    5,737
    301
    2016
    Quote Originally Posted by M Code View Post
    Sir
    Errr?
    No it's not. NPT is a tapered thread, so even if you could make a "perfect" drill hole, it would only be "perfect" at one depth.
    Regards.
    Mike
    Sep 2015
    Ohio
    1,954
    1255
    2101
    Your drill ain’t gonna drill to .438 anyhow. Just do it.
    May 2011
    New Jersey
    3,798
    439
    2210
    You would be fine 5k bigger...you do know the actual gap size of .0005 right? Most household aluminium foil is .93 mils or .00093. So figure half that is 5 tenths. Threading is probably the least hole dimension specific.
    Im in a toolroom working on molds and fixtures, along with other projects. I usually drill my holes 1 size over standard, if i want a tight thread i drill one size under. Npt I tend to stay on size just because a size higher is usually way to big. If it was a matter of 5 tenths I would close my eyes and grab either or.
    Plus, who reams for npt. Get that tap in there and armstrong it down... broke a 1" npt tap that way, brand new too, sent me half way across the shop. My coworker laughed his ass off. Big ass tapping wrench too. Npt is a whore when it's full depth in material.
    Quote Originally Posted by Finegrain View Post
    Errr?
    Regards.
    Mike
    Eh if it's a little too big...put a few more wraps of Teflon tape
  9. #8
    May 2011
    New Jersey
    3,798
    439
    2210
    Ddddddouble post!!!
  10. #9
    Dec 2018
    315
    755
    81
    Half a thou tolerance on a freakin NPT thread? Now I've heard it all!
  11. Likes plastikdreams, JohnEvans liked this post
  12. #10
    Jan 2007
    Flushing/Flint, Michigan
    11,371
    692
    9103
    To answer the question .
    NO difference. Even if it a was a very tight tolerance straight thread. No difference.
    First this in or just a bit outside the tolerance of making a drill, second they never make on size holes.
    This is a crazy worry.
    Bob
  13. #11
    Aug 2005
    CT
    8,697
    528
    2383
    Sir
    Not sure what you call tight tolerance, but NPT is gaged as +/- 1 full turn from gage flat ...
    IOW, for the 18 pitch thread the pitch dia tolerance is loose enough so much as to have the thread gage depth be varying .110 total!
    But to directly answer your question, that .4375 is actually .4396 dia at the L1 gage depth of .2278, so you will be more than fine with .438.
    Frankly, I'd probably drill that shit to 11.5mm if it's all the same.
  14. Likes Murf, Fancuku, doug925 liked this post
  15. #12
    Oct 2013
    New Jersey
    1,377
    7
    1181
    I hate pipe threads and in my previous job I worked at eliminating them as they are the #1 source of leaks. Got rid of about 90% and virtually eliminated all leaks. The reason it is so hard to seal them is that the peak of the external thread doesn’t completely seat in the root of the internal thread and viceversa. So you get a spiral leak path that just drips. O-ring, taper to taper, victaulic, Banjo flange, bolted flange, all are much better.
  16. #13
    Mar 2012
    Florida
    467
    1496
    190
    Are you thread milling? I haven't used a reamer in years for NPT. Even since I switched to thread mills I just go for it.
  17. #14
    Aug 2005
    CT
    8,697
    528
    2383
    Quote Originally Posted by garyhlucas View Post
    Well, that's what you get from China anyway.
    Guarantee you that an NPT that is made to specs and assembled with the proper sealant ( as it is meant to be assembled ) will not leak.
    I know that if I make both female and male pieces, I can make them hand tight only and use Vaseline as a sealing agent, they will seal 120 PSI air.
    I have made that test repeatedly!
    And you know what? The NPT specs state a very specific flat at the crest of the threads, and they do so for a reason!
  18. #15
    Nov 2002
    3,432
    2150
    913
    Hi
    Thnaks...
    None whatsoever. Nobody is ever going to know that you went 1/10th above the ~nominal~ callout.
    You could probably go to Ø11.2 or 11.3mm without too much issue.
    My $.02
    Doug
  19. #16
    Dec 2018
    315
    755
    81
    I work for a check valve company and one of their basic check valves has NPT thread on both ends (female on the inlet and male on the outlet). These valves are rated 450-6000 CWP.
    NPT threads are the better than straight threads for sealing.
  20. #17
    May 2017
    Minnesota
    2,475
    3441
    1801
    Used to threadmill NPTs in mold blocks for water and oil lines. No leakage whatsoever is permissible when die casting aluminum. They all worked fine.
    Tapped NPTs tend to leak where the flutes stopped.
  21. #18
    Aug 2005
    CT
    8,697
    528
    2383
    Quote Originally Posted by mhajicek View Post
    True, but that is why there are spiral flute NPT taps: https://www.mscdirect.com/browse/tn/...?navid=2106059
    One of a local manufacturer specifies each tapped port on their prints: No straight flute tap allowed!
  22. #19
    Jan 2018
    ALAND ISLANDS
    93
    10
    22
    I'm curious, was most of the leaks in heat treated blocks?
