Hey guys long time lurker here,
Our shop was commissioned to do a 0.500 - 14 NPT Thread in a SS forged material.
This is the first time I do NPT threads. The customer sent us a gage with 3 planar surfaces along the thread. I am using this explanation to measure it.
https://www.threadcheck.com/technical-documents/taper-pip-thread-gages-pg12.pdf
I wanted to know if you have any recommended cutting conditions.
Seco recommends the following with an HSS tapper (MTH-1/2-14NPT-XC-V048):
Cutting speed 29.5 sf/min
Coolant media Emulsion 10%
RPM 137 rev/min
Feed speed 10 inch/min
Recommended pre-hole diam 0.7047 inch
Maximum pre-hole diam 0.7067 inch
But I am Using a 1/2-14 NPT 4 Flute High-Speed Steel Standard Flute Tap from Kennametal. And the previous supplier used S20 F1.4 in/min. Which is different from SECO web page.
Thanks in advance for the help,
RPM 137 rev/min
