Hello,
i'm a student in cnc got a question.
Want to be in the tolerance i know +1 in z in the tool wear means it till goes to 5 instead of 6mm in z. But how does radius work? -0.5 on a end mill on contour and pockets means it will be 1mm smaller? Becouse i want to make it smaller first so i can change and the tolerance will be perfect.
Using a Dmg MOri eco mill with Siemens.
/Thanks Phil
/Thanks Phil
