Okuma cnc lathe
Results 1 to 9 of 9
Thread: Okuma cnc lathe
    Dec 2013
    ontario canada
    16
    Default Okuma cnc lathe
    Looking to buy 1996 OKUMA CADET LNC 8C “BIG BORE” CNC TURNING CENTER. Any problems? Is it a solid machine? Looks like in great shape.
    Jun 2012
    Michigan
    4,632
    4240
    2797
    Quote Originally Posted by sash1ca35 View Post
    Uhhh.........
    Jul 2003
    Carson City, Nv. USA
    902
    710
    480
    They are built like tanks. We have a 96 & it will run tenth work all day long. We also have a 2004 Captain L470, & while a solid and very accurate machine, it is a gutless wonder for a 15" chuck machine. We can push almost a big of insert drill in the cadet as what we can push in the Captain.
    Nov 2013
    Utah
    4,499
    1187
    2480
    I like the color schemes they offered in the Nineties.
    Aug 2014
    Indiana
    137
    106
    230
    Was it the off white in the nineties or did they still have the puke-green colors?
    Nov 2013
    Utah
    4,499
    1187
    2480
    Off white wasn't until 2000. Think green coolant tank and beige door. Diagonal badge that says "Cadet".
    R
    Jun 2019
    Maryland
    213
    34
    We had 1 of these at Beretta that we bought new in about 90. it ran 24/7 and was pulled out of commission last year. it made millions of barrels from rectangular stock ( so it was a heavy interrupted cut) I honestly cant say enough good things about the Cadet !!
    Feb 2007
    Boston MA
    1,014
    363
    864
    Never owned a Cadet, but Okuma is as good as it gets. I've owned and run Mori-Seiki, Kitamura, Mikron and other 'high-end' machinery, and nothing is built like Okuma. It's sort of like their engineers said "forget price, what would be the absolute most bulletproof way to design 'x' on a machine?" and then they did that. Not cheap to fix, but they run forever and hardly ever break. I have 35+ year old Okuma LC lathe that fires up every day and cranks out parts and holds a tenth all day long without missing a beat. I've made countless thousands of parts on it and the only problems have been stuff like a worn our relay, limit switch, and the occasional gasket/seal that needs replaced. Pretty good for a machine almost as old as me.
  9. Likes cnctoolcat liked this post
  10. #9
    Oct 2019
    Missouri
    I agree Okumas are the best. We have an LB-15 in our toolroom that is still going strong after 30 + years. We use it for hard turning heat treated tool steel as well as anything else we turn in the lathe. I got hired in as a machinist to make replacement + new die components for our stamping plant in St. Louis Missouri. It is the reason I was hired over other candidates in the first place. They originally turned their lathe parts on conventional lathes. I previously worked at a Screw machine plant also in St. Louis and having previous experience on this machine is what got me hired. I really like the Interactive Graphic Function software that comes on this machine that just by answering questions on the screen it will write the G + M code programs. Ours is so old it uses "get this" 8" Floppy disks. The strange thing is we have only 1 Floppy disk in 30 years that has ever went bad. In my opinion you will love your new machine.
  11. Likes toolmaker96 liked this post
