Okuma CNC Lathe - 2006 - business/commercial - by owner - sale
This is an okuma lathe locally in portland.
Any opinions on this as a used purchase, warnings, advice and ideas requested.
They are an ok machine, when it comes to Okuma. We have a 470 with the same control. We also have a 95 8" Cadet with the 5020L control. I can tell you this, you can push the cadet at least as hard if not harder than our 470. Biggest difference is that the old cadets were 2 speed gear boxes, where the Captains are direct drive. Our 470 also as the same size turret as our Cadet. Which for a 15" chuck machine, the turret is way undersized.
Another minor gripe about the machine is the control takes forever & a day to boot up. Of course I guess this is not all that uncommon, seems like all of our newer machine the controls are extremely slow to start.
As 70olds says, the tailstock is in fact a tow along & manual clamping. However, everything we do is either one off, or very low qty. & so this feature is not a big deal.
On the + side, the machine is every bit as accurate as you would expect from Okuma. Also, while the turret is undersized, they did stick with the curvet coupling design.
One other personal observation; any photo of a lathe for sale that had a picture of a tail stock with no plug in the bore, I would either take a pass on, or at the very least go over the machine with a fine tooth comb. I would worry about the upkeep on a machine, when they cant even be bothered to plug the quill.
