Had a question regarding the single blocking on an Okuma Law 2s with OSP 7000L controls. When going to single block the machine you have to use both green cycle start buttons and hit them at the same time for every line of code. I was wondering if anyone knew if/how you can change a parameter to make it single block using only cycle start button. As you can imagine it is very difficult to hit both cycle starts at the exact same time for every single line of code.
