Hey guys I have been fighting with this for a couple weeks on and off. This machine is new to me and have yet to be able to run any programs.
Attached are 2 pictures one of the g-code while editing and the other is once the program is loaded.
I can run commands in MDI and the machine responds as expected but not from a loaded program.
This code isn't to do anything but just test the machine using as simple code as I can use.
What happens when I load the program is only shows the very last line of M02 no other code is displayed when I hit cycle start the machine makes a click as if its doing something but then just runs the M02 line and stops. I have it in single block but it has no other lines to stop on.
Really confused as to what I'm doing wrong here.
