Okuma LU35 OSP P200L control
Likes Likes:  0
Results 1 to 7 of 7
    Sep 2018
    Default Okuma LU35 OSP P200L control
    Anyone have any experience programming this machine?
    Any info greatly appreciated
    Nov 2013
    Utah
    4,670
    1238
    2618
    I have experience. What do you need to know?
    R
    Jun 2016
    23
    7
    ^^^^^^What he said. The more specific the questions the better.
    Jun 2011
    New Jersey
    916
    548
    351
    A great control. What's the issue?
    Sep 2015
    Ohio
    1,173
    734
    1175
    Musta got it figured out.
    Nov 2013
    Utah
    4,670
    1238
    2618
    He contacted me. The issue he's having is using the P values to coordinate upper and lower Turrets for pinch Turning. I haven't done it in several yrars and obviously wasn't standing in front of it. So couldn't help.
    But if anyone could lay down some wisdom on the topic....
    R
    Jun 2016
    23
    7
    If he can post some sample of what he is doing we can probably fill in the blanks.
    Generally you would want to run your two turrets into position, with the chase/deeper tool set at the respective distance and P-Code those lines as they match up. Then if they meet (hold) at the start point and will be travelling the same distance at the same rate, you will follow through properly. The P Codes can be done in tandem (same code on both sides) as a hold point to match up or you can just alternate as you let one or the other turrets move. Some times you get errors if you don't properly align your spindle codes. Spindle speed changes often need to be done on wait coded lines for each of the turrets.
