Hi all.
We have an older Fanuc Wire EDM which has a CRT monitor. This monitor is dying and arbitrarily switches off while machining although it doesn't affect the machining, which carries on as if nothing has happened. A quick switch off and on temporarily solves the problem, but it continues to switch off, only the monitor mind, not the machine. After a quick look an engineer told me the monitor was on its way out so it got me to thinking about hooking the EDM up to a newer LCD screen.
I did read up on another thread here about a CRT to LCD conversion but that was a while ago now so thought it better to start something new.
A sync-converter was mentioned, not sure if this is the way to go, but connecting up an LCD screen to our 30 year old EDM doesn't appear to be straightforward.
Any advice/help would be appreciated.
Thanks.
Kris.
Thanks.
Kris.
