Opening chuck
Results 1 to 17 of 17
Thread: Opening chuck
    Aug 2002
    Regina, Canada
    2,395
    5
    82
    Default Opening chuck
    I have a Nakamura TMC 15 lathe with Fanuc 18T control. This machine at one time had a bar feed so I assume there is a code to open close the chuck but I can not find reference in the manual. Is there an M code to do this and if so would it depend on the type of bar feed?
    Bob
    Jun 2012
    Michigan
    5,201
    4778
    3149
    M10/M11?
    M17/M18?
    Generally M codes are different by manufacturer. I'd check with them.
    Jun 2018
    Idaho
    147
    36
    30
    Should be M68 Chuck Close M69 Chuck Open. But it can vary as Mtndew said.
    Jan 2014
    Washington
    5,191
    933
    2816
    As the others have said, could be anything. You won't find definition of most M-codes in the Fanuc manual because the machine builder determines the function of M codes within their ladder program. Look in a Nakamura programming or operation manual. Most builders try to use the same M codes across their range of similar products, but even that is not guaranteed.
    Jan 2017
    Oregon
    3,623
    767
    2508
    My lathe uses M34 and M35.
    Try to find an old barfeed program from that machine. Or look at the 8000/9000 programs, there might be a program in there that has the code.
    Apr 2005
    Beaverdam, Virginia
    8,305
    967
    4065
    On my Fanuc 0T it is M68/M69 on the 21T it is M10/M11
    Dec 2011
    Illinois
    91
    7
    15
    M11 / M10 on my Nakamura
    Apr 2005
    Beaverdam, Virginia
    8,305
    967
    4065
    I don't think there are any M-codes that could do harm to a sitting machine. I would just input 1-99 in MDI if I could not find a list. I doubt it is a 3 digit one.
  9. Likes Ox liked this post
  10. #9
    Aug 2013
    Chicago, IL
    1,030
    730
    401
    I do not think the type of barfeed would affect the M-codes used for opening/closing the chuck.
    Are there any old programs in the memory you could look at for reference?
    Along the lines of what Dualkit said, you could write some incrementally-increasing macro and just watch it until the chuck opens:
    #500=1
    N1
    M[#500]
    G4U1.
    #500=[#500+1];
    GOTO1;
    hmmmm, but I wonder if you would get an alarm with, say, M3 without an associated "S" word :scratch chin:
    Good luck with your new machine!
  11. #10
    Jan 2014
    Washington
    5,191
    933
    2816
    Quote Originally Posted by Dualkit View Post
    Not necessarily true. Some builders have interlock cancel or maintenance type M codes within that range. If you actuate them, then stuff like opening the chuck when the spindle is running or doing a toolchange without the head being at zero return become possible. A good example is some Mori Seiki machines use M31-M35. Makino, knowing that folks might poke around blindly at M codes, made their maintenance codes high 3 digit numbers. Less likely that someone would stumble onto one and create a dangerous or damaging action.
    Again, the machine tool builder defines what most all the M codes do. Because of that it is not a real good idea to blindly try activating them.
  12. Likes Nerdlinger, gregormarwick liked this post
  13. #11
    Aug 2013
    Chicago, IL
    1,030
    730
    401
    Okay so maybe ignore what I said
  14. #12
    Apr 2005
    Beaverdam, Virginia
    8,305
    967
    4065
    Wouldn't cycling through numbers in sequence turn them on and then back off again? So no harm no foul?
  15. #13
    Jan 2014
    Washington
    5,191
    933
    2816
    Again, up to the builder, so only if they made them to act that way. In the Mori example, M35 has no cancel code. M31 is canceled by M32 and I do not recall about M33 and M34. M35 is pretty innocuous on most of their machines. It clears tools from the spindle back to the magazine and updates the PMC parameters accordingly. On their M300 series it can leave the transfer pot engaged with the magazine. Then the next magazine rotation whether manual or programmed causes a PITA jam-up to untangle.
    The point being, there can be risks to blindly activating M codes where the function is not known or understood.
  16. #14
    Apr 2005
    Beaverdam, Virginia
    8,305
    967
    4065
    I have a machine that uses M codes for tool positions, but the machine is very simple, all 8 tools on the same gang assembly without a sub, so no chance of an accident arbitrarily punching in M-codes.
  17. #15
    May 2006
    Burlington, North Carolina
    420
    488
    161
    Quote Originally Posted by bob View Post
    We have 5 Nakamuras, 3 with Fanuc 18i controls and two with 16TT. All of 'em use M11/M10.
  18. #16
    Apr 2005
    Beaverdam, Virginia
    8,305
    967
    4065
    Quote Originally Posted by aj View Post
    I think if you took a poll M10/M11 is by far the most common. I would just punch that in and see what happens.
  19. Likes Nerdlinger liked this post
  20. #17
    Jan 2013
    Plainfield, Indiana, USA
    1,804
    1383
    958
    After experimenting with punching in unknown M codes, just shut the machine down and re-start it. Should reset everything to normal start-up conditions.
  21. Likes Ox, Vancbiker liked this post
