runninwideopen
- Oct 31, 2014
Hi all,
I'm cutting A514 Grade Q for the first time. My tool life is much shorter than expectations.
IE. 3" Facemill, 8 inserts. Removing about 10lbs of material each part. Inserts need rotated/changed every 3 parts.
5/8" 6flt chip breaker rougher Removing about 5lbs of material each part. 450sfm, .007"ipt, 5% stepover. About 5 parts.
1/4" 4flt rougher. 450sfm, .0032ipt, 5% stepover. And, helical milling at 350sfm, 2 deg, 12ipm. About 3 parts.
All coated carbide. Facemill is TIALIN. end mills are proprietary.
I've found this steel work hardens easily, so I'm using coolant. Would it be better to cut these dry?
Does my wear sound expected?
