vmipacman
Cast Iron
- Nov 21, 2014
- Virginia, USA
I have a one off aluminum part approx 12" x 40" 4". Its one in a set of several but they are all different and this is the only one with this particular issue.
Notice the overhanging part of the radius. This is just a quick representative model of the problem feature for clarity.
The others parts I have done with a 1" carbide ball. All good. Now that this one is roughed out I set it to the side until I come up with a finishing plan.
Option 1: Order a spherical or lollipop cutter.
Pros-
-No complex fixturing,
-faster setup,
Cons-
-I am Having slight trouble with HSMWorks getting the exact tool path I want (but can prob get there),
-expensive(ish) cutter,
-need ~4" reach so need carbide, and bigger than 1" wasn't coming up on first searches.
Option 2: Laser cut and weld up sine plate fixture for positioning about 20deg angle.
Pros-
-Simple reliable toolpath with existing tooling
Cons
-Cost in money and time of fabbing/designing one time fixture
-More complicated setup but I did leave two pin holes in remaining stock, so could use tooling balls for indicating.
Altered option 2:
I feel comfortable designing some laser cut plates with interlocking tabs and welding together. For the tolerances needed on this part I can rely on the lasered angle being accurate enough. But also I have no experience with real SINE bars. Would a few of these be a better choice than a one time fixture?
1x11" Sine Bar
I'm not taking too many heavy cuts now that it's mostly roughed, but I worry about rigidity if th setup is too hacked together.
Thanks for any push int he right direction you can give.
Pros-
-faster setup,
Cons-
Pros-
Cons
Altered option 2:
1x11" Sine Bar
