In our workshop we have several CNC lathes/millers all using Fanuc controllers from 18 to 32i with the Manual Guide/EZ Guide option which we use extensively. We also have some Fanuc based machines without the guide option. When I need to transfer production of a complex part to an older based controller I will convert a Guide program to NC code using the NC convert command. On some guide based machines this will output the NC code with all the axis and feed values on every line whilst converting on another machine will output code with only values that are to updated movements on each line. What I would like to do is setup all the Guide based machines to output the same shorter format NC code.
Are there any application engineers or savvy’ guide based users out there who could point me in the right direction of which parameters/settings to alter. Thanks
