Part Material Selection
Results 1 to 9 of 9
    Jul 2020
    CANADA
    Manitoba
    88
    35
    Default Part Material Selection
    Good day everyone.
    I am making a set of punches for an air hammer, starting with 3/8" diameter up to 1.50" in 1/8 increments. Could anyone recommend me the best material to use for this job? It needs to hard so it does not mushroom when used, but at the same time not brittle so it doesn't break easily.
    I appreciate any insight given.
    Thanks.
    Jun 2012
    Michigan
    6,162
    5767
    3935
    What material will you be hammering?
    Maybe try a hardened tool steel of some sort.
    May 2017
    Minnesota
    2,136
    2924
    1536
    Hardened S7 would likely serve you well.
  4. Likes Dan from Oakland liked this post
    Jul 2020
    CANADA
    Manitoba
    88
    35
    Just pins, mostly 4340 and equivalent.
    Jul 2020
    CANADA
    Manitoba
    88
    35
    Quote Originally Posted by mhajicek View Post
    Would this require hardening after machining or ready for work after i have turned it?
    Also, how is the machinability of this material?
    Jun 2013
    Oregon
    2,012
    738
    1225
    Just make sure it is made from billet.
    Jan 2014
    Washington
    5,738
    1010
    3231
    This ^ X10
  9. #8
    May 2017
    Minnesota
    2,136
    2924
    1536
    Quote Originally Posted by jephw View Post
    You can hardmill and hardturn it in the hard, but it'll be easier to machine soft and then harden. Do any polishing after hardening.
  10. #9
    Jul 2015
    Wisconsin
    238
    16
    88
    Agreed, S7 is the best option. We have a part we make from S7. The first time we made it we used annealed S7 then hardened. Pretty stringy and was hard to break a chip. Since the part only gets hardened to 40-45 HRc we started hardening the part before machining. Almost machines like a 4140 prehard but not quite as crisp. You will likely want to go harder, quick googling says about 55.
