Im considering buying an angle head for a job and wondering what kind of a cut I should be expecting to be able to take with it and most importantly what kind of finish I should expect. This batch of parts are only delrin but I need to machine an O-ring sealing bore 1.25" deep and this will require a good finish.
My only previous experiance with an angle head was at the last shop I worked at several years ago. They used a long, probably 12 inch, slim centerline angle head and it was a disaster. That thing wouldnt cut butter. Chattered like crazy as soon as tool hit the work even with like 5 thou cuts. Bearings went in it part way through the job, it was a mess.
I just stared looking recently so open to suggestions. Im thinking of going with something along the lines of this: GS GFX16 ER 25 Fixed 9o Right Angle Heads - Penn Tool Co., Inc
