kap pullen
Cast Iron
- Jan 4, 2002
- Maryland
I've purchased a Fadel on line and would appreciate some opinions on phase converters.
My Bridgeport cnc ran off a phase converter for some years. It was hooked up so the control ran from the two hot legs instead of the generated leg.
The Bridgeport has now been retrofitted with an AHHA control. The Ahha runs on 110 volts so that is not an issue anymore.
I plan on doing the same with the Fadel as far as using the hot legs for the control.
Is there a need to purchase a "CNC" converter?
Small cnc converters are not expensive and I could purchase one and dedicate it to the Fadel.
The cost of true 3 phase from the power company
is prohibative to have installed.
Thanks for your opinions.
Kap Pullen
Kap Pullen
