updatedsecurity
- Jun 6, 2021
Hello.
I have this part that I need to do in 6061. My thought was to do op 1 in a collet chuck and then switch to a jaw chuck and cut pie jaws. I plan to grip on the straight section. The machine is an LB 3000 with a 10 inch chuck. Do you think I will have enough clearance to clear the bigger diameter? Or do you have better ideas on how to hold the second op.
