I am using a sandvik 50mm r490 cutter - 1040 grade. Wanna get some advice to increase my tool life ... at the moment I do climb milling ... cause I thought that I wanna avoid conventional milling otherwise it creates too much heat ... which is as far as I know bad for machining stainless ... but entering the hard plama cut surface isn’t very good for the insert either .... should I try conventional milling .... or even maybe use a different tool ... maybe endmill - conventional milling ...just to get rid of the hard surface ... thanks in advance for any advice . Ben
