Hi everyone.
we are asked to machine a part with a strange thread .
the part is 180 mm in diameter that should be variably threaded ( G34 in fanuc ) with a 25 mm circle insert . ( the profile of thread is 25 mm semicircle )
the problem is that because of the machining load on 25mm insert i'm gonna use a 8mm insert instead .
i can use software to create the 25mm semicircle profile with 8mm insert but i don't know how to make it variable because this strategy is not available in cam softwares .
the picture shows the compensation of 8mm insert for 25mm profile .
Regards
behnod
Regards
behnod
